SALE: Performance Parts!!! Now with Prices ONO
- 480 Veteran
Upgraded Turbo from "Vader", never used been sat under the bed for the past 3 years. In VGC, can create tons of boost and still remain in its efficient operating area. £180 SOLD
B18E Camshaft, longer duration and lift. Suitable for all 1.7 engines, will increase power and move it slighty up the rev range. Slight surface, but stored inside for past 2 years and will not affect running. Lobes are all good. SOLD
Strut Brace, fits all 480s and maybe 440/460 too. Really sturdy build by Chris1roll. SOLD
Innovate LC-1 Wideband Lambda Controller with brand new sensor. £90
Megasquirt v3.0 with 4 ignition drivers mounted in an old LH2.2/EZK box. £170
Saab 2.3 Turbo 16v High-Impedance Injectors, think about 300cc.
3bar Fuel pressure regulator, ideal for running high boost without pressurising the fuel system/injectors too far.
Rear Spoiler for 480 with brackets, painted in 311 Lavender Metallitc (not the best paint job!). With two brackets. Made by DBS (search forum £50
Fuel Filter. £5
Cam Shaft Seal (cam belt end) £3
Rocker Cover Gasket. £3
Can get photos. Loads more parts avialable, also interior stuff too. Sad time ahead
Fuel Filter. £5
- 480 Veteran
Sub designed for the 480 boot, with two 10" REL drivers and covered with boot cover material to match interior. £40
7" TFT Screen, very high quality will do 1024x768 and text remain readable. £85
Unofficial foot well lights with loom to connect to ignition lock light. £15
Dash Board surround, in good condition, very small crack in usual place, not noticable. £20
Boot/Petrol flap release trim, upgraded from standard to never break again with allen bolts, no need to remove seat to replace. £15
Mint condition leather inserts for doors, dash etc. No ripples in at all, not seen many in such good condition. £25
Electric ariel, good working order. £20
Clear side repeaters, made by some guy on here, about 5 years old but perfect condition still! Uber rare. SOLD
Most interior trim available.
- 480 Veteran
TechniClutch 215mm for later Turbo models, uprated to hold more torque. £85 SOLD
4x Unused still bagged Wishbone bushes, might be volvo ones not sure. Suit manuals. £20 SOLD
id like the cam if its still about
[img]http://img.photobucket.com/albums/v485/badboi106/sigs/daver5new.jpg[/img]
renault shell, custom cage, no dash, volvo engine, nissan turbo, apexi boost controler, ksm re-wire, persision automotive down pipe, dta engine management to come. 175 BHP 220 LB/FT torque
ring me for parts 07805391168
- 480 Veteran
Been a bit overwhelmed with PMs! Also don't have internet at home at the moment so have to be quick with the forum.
Can post anyweher in the world, larger items will be done with interparcel to keep it cheap and trackable.
I may need to ebay or something as I've had so many PMs on items, or perhaps add some price list...
- 480 Veteran
- 480 Veteran
I have Rear Clusters too, they are about 3 years old. They were bought new from Volvo with fitting kit supplied from a German Ebayer. I might sell them if I can have an old set in return.
1x Turbo cambelt tensioner, can't remember which one it is, PM and I can get a photo or part number. £10
- 480 Veteran
- 480 Veteran
- 480 Veteran
can u do a better price on the lc-1 afr sender and sencor
does it come with a guage?
