auxilary gauges wanted/sorted now
auxilary gauges wanted.good price paid .thankyx
its an 1991 es.dont know the pin?do they both work
- esta
Re: /
Yes both workted clutch wrote:its an 1991 es.dont know the pin?do they both work
6 pin means that you link the turbo gauge in-obviously if yours is an ES there is no turbo to give you readings. I ran my GT on turbo 6-pin gauges, it basically just means that there is a turbo reading dial which does nothing lol!
Whereas a 4 pin gauge just has the oil and battery dial and a blank with VOLVO on!
HAVE: Jaguar XJ40 4l Sov
www.projectjaguar.co.uk
thanks.thought as much.the turbo gauge will still move in the lower region but not go into the boost.handy as an economy gauge.not bothered which type i get.just want it to light up good in the night time.
- esta
Re: /
No, the turbo gauge wont move at all, because all non turbo 480s have a 4 pin connector in the dash which will link to both the 6- and 4-pin gauges-but obviously on the 6 pin guages, it will only link to the first 4 (which are the battery and oil). I am awful at explaining things, so I hope that makes sense...???ted clutch wrote:thanks.thought as much.the turbo gauge will still move in the lower region but not go into the boost.handy as an economy gauge.not bothered which type i get.just want it to light up good in the night time.
i ungerstand.ill just blank that part off.zx
Esta is wrong the number of pins does NOT correspond with the number of guages , A four pin will have a common return wire . You can get a set of guages from a turbo which will have turbo / oil pressure and / voltage with 4 pins.
In fact Cerberus took out his analogue clock and replaced it with a voltage guage .
my ears are open glasgiejim
how long does it take to pm .not here yet
- esta
Thats wierd! I can only apologise @ ted clutch! I have only had one aux gauge with turbo and that one had 6 pins and my one without the turbo gauge had 4 pins, so I just assumed all turbo ones had 6 pins! My bad!glasgowjim wrote:Esta is wrong the number of pins does NOT correspond with the number of guages , A four pin will have a common return wire . You can get a set of guages from a turbo which will have turbo / oil pressure and / voltage with 4 pins.
No Esta which is why I asked how many pins.esta wrote:Thats wierd! I can only apologise @ ted clutch! I have only had one aux gauge with turbo and that one had 6 pins and my one without the turbo gauge had 4 pins, so I just assumed all turbo ones had 6 pins! My bad!glasgowjim wrote:Esta is wrong the number of pins does NOT correspond with the number of guages , A four pin will have a common return wire . You can get a set of guages from a turbo which will have turbo / oil pressure and / voltage with 4 pins.
- esta
oooo i see! I thought you asked cos i thought turbo had 6-pin and es had 4 pin! Durh!martinholmesuk wrote:No Esta which is why I asked how many pins.esta wrote:Thats wierd! I can only apologise @ ted clutch! I have only had one aux gauge with turbo and that one had 6 pins and my one without the turbo gauge had 4 pins, so I just assumed all turbo ones had 6 pins! My bad!glasgowjim wrote:Esta is wrong the number of pins does NOT correspond with the number of guages , A four pin will have a common return wire . You can get a set of guages from a turbo which will have turbo / oil pressure and / voltage with 4 pins.
