Glasgowjim's spares list
Re: Glasgowjim's spares list
Hi Gasgow Jim
I'm looking for
A working clutch cable ( mine is really stiff)
A working light switch ( mine has to be manouvered to bring the info centre up )
The rubber pipe connecting air cleaner to inlet manifold. And
A passenger side working pop up headlight motor
Any ideas?
Regards
Ken Hoyle
I'm looking for
Any ideas?
Regards
Ken Hoyle
Hi Ken will check out the clutch cables tomorrow.
I have the variable resistor that is located on the under side of the steering column. Will check if I have the rubber tubing you are looking for. I definitely don't have the pop up motor .
GJ
GJ
Hi ken
your clutch cable is and early type part number 3459869 I only have the later type part number begins 370......
I believe the difference is in the length of the cable as the later one is slightly longer 1.5 cm but I could be wrong I remember having to measure clutch cables to find the correct one.
I suspect that the airpipe may be different as well but I will look out the ones I have and either locate the part number or photograph them for you.
the hose connecting the airfilter to the inlet manifold has a part number stamped on it .
The spares I have are part number 463161 /03
Hi Jim
Would You happen to have a indicator stalk amoung Your spares? if so I would very muck like to buy one.
thanks
Chris
thanks
Chris
- doingitsideways
Hi Chris.
If Jim can't help you out, I've got one know knocking about![Wink ;)](./images/smilies/wink.gif)
Steve![Hopping Happily :hopping:](./images/smilies/hopping.gif)
Steve
Hammers can't fix a 480!!!
Thanks Steve
I might get back to You
Chris
![Smile :)](./images/smilies/icon_smile.gif)
Chris
Hi Chris yes i should have one of these but its too late now to check will post up tomorrow
OK Jim
Chris
Chris
Chris you have a pm ![Very Happy :D](./images/smilies/icon_biggrin.gif)
And if GJ cant deliver ... u know where u find me ![Wink ;)](./images/smilies/wink.gif)
Regards Daniel
Regards Daniel
If u need spares feel free to contact me. I ship to whole Europe incl. UK.
www.480er.com
www.480er.com
Chris need you have a pm and email message...... ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Hi Glasgowjim,
I'm looking for a working headlight electric motor ( passenger side ) for my 1.7 es/sr .Also a headlight switch and a sunroof electric motor ,as mine only works in one direction. Would tou be able to supply these please,or perhaps know someone who can?
All the Best
Ken ( Hoyle )
All the Best
Ken ( Hoyle )
the popup motors are not sided (headlamps).
the fact that the sunroof only works in one direction is not because the motor is faulty but that the plastic connector rods are broken.
headlamp switch I have spare of this .
As long as the motor is actually working even in only one direction then it is the connector rods that are the problem and these are far easier and cheaper to fix than the motor. I have spares of the moonroof motor and the plastic connector rods but I am afraid I do not have any popup motors spare.
Can I suggest that tyou double check the moonroof as volvo calls it sun roof to everyone else. If the motor is ok the roof should go up but not down without being pushed down this is a classic broken connector.
Once you know what you need I can give you a price with postage for the lot rather than bits and pieces as it is cheaper that way. I check the forum usually at least once a day and with royal mail first class you can expect delivery within 48 hours unless you are in a flooded area down south.
Hi Jim,
Do you have a driver's side door pocket in good condition?
If so, how much including p&p please?
Cheers,
Nigel.
Cheers,
Nigel.
Yes I have a door pocket in good condition will pm you tonight as still at work ![Wink ;)](./images/smilies/wink.gif)
Nigel you have a pm ![Wink :wink:](./images/smilies/icon_wink.gif)
check out first post in the thread have new additions to parts list.
couple of parts needed.
I need the surround piece's for a post '92 Drivers side wing mirror.
paint is 305 Black (Base Version with Red Tint not option version with blue tint) but it doesn't really matter as I'll respray it.
Slash it would need to be a whole mirror assembly as the plastics cant handle being removed without snapping somewhere . I know I have tried in the past
Have a complete mirror unit drivr side but not in black. the postage is quite expensive all in it would come to £24
![Crazy :crazy:](./images/smilies/nuts2.gif)
