Glasgowjim's spares list
Re: Glasgowjim's spares list
hey Jim did you ever down to my last P.M I sent ?
looking for the ashtray insert too now as well as the other bits.
Look forward to hearing from you
Pete (Wanderer)
Pete (Wanderer)
1995 Celebration 332
Would Mr Glasgowjim be interested in selling me a small portion of his spares list?
onle a few bits and bobs and the odd hard to find ones?
89' 480T - low n slo :-{)
If I have it yes.
![Nuts :nuts:](./images/smilies/nuts3.gif)
![Nuts or Blabla :bla:](./images/smilies/nuts.gif)
![Rolling Eyes :roll:](./images/smilies/rolleyes.gif)
![Crazy :crazy:](./images/smilies/nuts2.gif)
Jagwaa be aware the there are to my knowledge at least 3 types of radiator!depending on year and wheter air con or not. You can change radiators around but it does mean the pipes need to be altered . It just your luck really. ![Rolling Eyes :roll:](./images/smilies/rolleyes.gif)
Hi Jim - I hope all's well?
That's a mighty impressive parts list - and the photos! It has to be said, the service you provide the Volvo 480 community on here is tremendous and absolutely invaluable, Jim!
I noticed you have a passenger side door pocket in your list. Do you still have it please? I'm in need of one in good condition and a lightbulb holder/socket for my offside front day running light. Also, can you advise me please... I have a spare (used) auto drive shaft, which was sent to me some years ago by mistake for another 480 I had at that time. Can you tell me if the CV end bit on this are inter-changeable with 2.0i manual, please? The CV joint on the nearside is showing definite signs of wear.
Many thanks and kind regards, Nigel
Hi jim,
thanks for the update im not sure on which radiator mine is as its and early 89 model. (need to get part numbers and get back to you)
i have found out that i may have fixed my overheating problem though, but i guess im gunna find out the hard way.
Anyway, i'm in desperate need for a Drivers door seal and Drivers door bridge, if possible could you PM me with price and payment options?
looking to get it on the road in the next week as my other wheels have packed in.
cheers!![Smile :)](./images/smilies/icon_smile.gif)
cheers!
sorry Jaagwa what do you mean by drivers door bridge ?
by drivers door seal do you mean this...
![Image](http://i223.photobucket.com/albums/dd271/glasgowjim/clip005_zps484ab860.jpg)
hey jim, thanks for the speedy reply!
yeh correctemundo! that seal looks pukka one of them will make me a happy bunny.
as for the Bridge, what i mean by that is the strut attached to the door which stops it from swinging out wide. ive not had oneon mine since ive owned it.
hope this helps![Smile :)](./images/smilies/icon_smile.gif)
hope this helps
Hi Jim, If you still have Front Headlight with motor (RHS), I would be interested in buying. Please send me your price, along with post to France.
Cheers Phil
Cheers Phil
Up dated list
2front seat belts (fullset)
4 rear seat belts
1 fullset of seat belts front and rear.
2 under engine plastic covers
1 large bag of assorted wiring partial looms connectors etc.
1 bag of assorted rubber seals , hoses etc
1 heater assembly
2 rh front wheel arch protectors
1 lh front wheel arch protector
4 plastic rear suspension stoppers/bumper stop
4 outer upper top side trim (for above rear windows) 2 paris blue 2 white
4 rear hatches
1 main exhuats for 92 1.7ltr with cat (new)
2 radiator fans
3 cabin fans
1 bonnet
4 rear hatch struts
5 pairs of rear side windows
7 front door windows (3 pair + 1 single)
4 near side quarter light windows
5 off side quarter light windows
5 power steering pumps
1 red dip stick
1 green dipstick
2 screen washer tanks
2 brake servo units with relay
2 power steering racks
1 rear anti roll bar
1 pair of drive shafts
2 gear selector rods
2 cats (2ltr)
1 M60 gearbox
4 radiators
3 heater matrices
1 complete 2 ltr inter cooler to downpipe connector
2 2ltr intercoolers +throttle bodies
2 complete wiper assemblies +motor
1 wiper motor only
7 92 onwards front engine mounts (newstyle)
2 post 92 rer engine mounts
2 post 92 rear engine mount frame
1 alternator mounting frame
4 clutch cables (later models)
4 accelerator cables (late model)
4 interior roof lights
LHS long range driving lights
2 pr rear bulb holders
2 battery earth straps
ignition units and capacitor for non turbos.
5 bonnet hinges
1 red plastic tub of various lock mechanisms
3 complete gear levers
4 horns
2 moonroofs
4 idle control valves
1 complete dash board with loom
multiple all interior trim except the plastic housing surrounding the petrol tank-rear hatch lever
multiple vents
abs controller MK2
front headlamps
analogue clocks
alarm led
2 heater slider units
2 doors (pair)
triple and double bank of light switches
multiple rotary switches
multiple instrument pod bulbs
4 rev counters
5 starter motors (1 new)
1 MBC (new and unused)
1 k&N type air filter
2 air filter boxes
several selector switches for info centre
multiple stalks wiper and indicators
4 water pumps
water washer pumps large and small
all small plastic trim pieces
SRS controller
Airbag
Airbag + steering wheel
airbag yoke
spare airbag "spring" assembly
electric aerial
umpteen rea light holders
petrol flaps
petrol flap spring loaded catch with and without the connecting wiring
bonnet latches
front internal black plastic "hood" for radiator
2 new ball joints
2 servo brake unit
pedal assembly
2 carpets (complete)
2 spare roof linings with moonroof aperture
2 rear roller boot covers
oh and heater resistor unit as well.
every bolt nut and screw ever put into a 480
plus umpteen other parts too numerous to mention.
way too much stored in shed and garage and storage box .
4 rear seat belts
1 heater assembly
4 rear hatches
2 radiator fans
3 cabin fans
1 bonnet
4 rear hatch struts
1 red dip stick
1 green dipstick
2 cats (2ltr)
1 M60 gearbox
4 radiators
3 heater matrices
1 wiper motor only
5 bonnet hinges
4 horns
2 moonroofs
multiple vents
abs controller MK2
front headlamps
analogue clocks
alarm led
2 doors (pair)
4 rev counters
2 air filter boxes
4 water pumps
SRS controller
Airbag
airbag yoke
electric aerial
petrol flaps
bonnet latches
2 new ball joints
2 servo brake unit
pedal assembly
Oh and some hens teeth parts......
small electric auxiliary water pump.
Jim you're like the Mecca for 480 parts, sent a PM :]
- doingitsideways
Go on then Jim, PM me with a price for a fuel sender unit... If you have one in the SoMD! ![Wink ;)](./images/smilies/wink.gif)
Cheers,
Steve![Hopping Happily :hopping:](./images/smilies/hopping.gif)
Cheers,
Steve
Hammers can't fix a 480!!!
Hi Steve will dig one out of the SOMD before the yanks invade the back garden and see how easy it is to disconnect from the complete fuelpump/sender assembly.
Don't suppose you've got any new heater slider knobs? :]
Steve you have a pm
Sam no have no slider knobs left but you can buy them from the volvo dealers for squillions of pounds. (ok slight exageration there only an arm and a bit of a leg)
macmartin you have a pm
![Laughing :lol:](./images/smilies/laugh.gif)
- timcoleman420
Alright Jim, how much would you want for a roller boot cover? And do you have the fittins etc for it?
tim you have a pm
tim you have a second pm ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Hello Jim. I send PM ![Very Happy :D](./images/smilies/icon_biggrin.gif)
ex v40 1.8
ex s80 2.4 D5
480se 1.7 Paris Blue
s80 T6
ex s80 2.4 D5
s80 T6
