Page 3 of 3
Re: Regretfully breaking 480 turbo auto
Posted: Wed May 11, 2016 12:41 pm
by jamesy12345
Alan 480 wrote:on the dash surround, where is hair line crack starting (as If I need to ask?)
i'm in ABZ so can you maybe weigh it and I'll see what postage cost would be. . . . . it's not heavy just bulky for GPO
I was thinking of the sticky vinyl repair method, as it would save taking dash apart (again)
have you still got BOTH snow mats? NB I could use it to catch the leak from teh heater matrix (I assume it is not available) although I might try and repair our one as car is off the road for at least next three months
and there is a spare that has been 'repaired' with silicon sealant
Alan the cracking is in the usual place, top left - I tried taking a photo although my camera is crap...I'll post it up later on see what you make of it
Snow mats are a set of 4 fella. Should be no problem to post them to Aberdeen
//edit
found the (fuzzy) photos, as you can or rather can't see it's hard to see the crack although it is there
and limits for parcel sizes
http://www.postoffice.co.uk/mail/uk-standard
if I can make the snow mats into a parcel less than 61cm long x 46cm wide x 46cm thick & less than 2kg it's only a fiver a go for 2nd class...not sure on the length of the largest mats though. The dash surround should be either 2.85 or a fiver depending on length (parcel needs to be under 450 mm long for the lower price)
heater matrix has gone unfortunately
Posted: Thu May 12, 2016 11:56 am
by Alan 480
Looks better than ours. !
have you scrapped the car?, if not do you still have the frame that the dash-surround fixes onto? most of the palstic fittings ./ screw holes are shot on ours so might worth doing the whole thing?
Posted: Thu May 12, 2016 12:44 pm
by jamesy12345
--------double post in error-----------
Posted: Thu May 12, 2016 12:46 pm
by jamesy12345
Alan 480 wrote:Looks better than ours. !
the car has gone now fella unfortunately, only these bits & bobs left
Posted: Fri May 13, 2016 7:11 pm
by doingitsideways
jamesy12345 wrote:
Stop masquerading as someone who knows what they're doing, with all the necessary toolage.
They're my ratchet spanners and Torx sockets!
Posted: Fri May 13, 2016 7:15 pm
by jamesy12345
doingitsideways wrote:Stop masquerading as someone who knows what they're doing, with all the necessary toolage.
I was looking at the photo thinking...I don't recognise them spanners....
my pound shop socket set must have been 'just out of shot'
Posted: Mon May 16, 2016 1:33 pm
by dcwalker
If it's any help I have the frame behind the dash surround on Nipper whom I am dismantling - not all screw holes are intact but most are; is it any good to you?
Posted: Mon May 16, 2016 3:11 pm
by jamesy12345
update
Relay cover
interior light
boot/fuel flap release lever cover
Snow mats
Ignition coil
Radiator fan & surround
Wing mirror glass both sides - provisionally sold
Recirc valve - provisionally sold
Dash surround in good condition with only hairline crack starting
Space saver spare wheel
Oil pressure/boost pressure/voltage gauge panel
Fog lights/rear screen heater switch panel
Digital clock - provisionally sold
MOMO steering wheel (not Volvo one)
Door handle/speaker covers
side repeaters
Posted: Sun May 22, 2016 6:37 am
by jamesy12345
Surprisingly I'll probably owning a 400-series again shortly...so now only the following items are available until I work out what is good/not good on the new car
side repeaters
not much left really, if no-one takes them say 3 weeks from now I'll be donating all parts to the local scrappy or similar
Posted: Sun May 22, 2016 10:00 am
by doingitsideways
jamesy12345 wrote:Surprisingly I'll probably owning a 400-series again
Surprising?
Who you trying to kid??
Posted: Sun May 22, 2016 10:11 am
by jamesy12345
doingitsideways wrote:jamesy12345 wrote:Surprisingly I'll probably owning a 400-series again
Surprising?
aye it seems like I'm a repeat offender
Posted: Fri May 27, 2016 7:52 am
by cranna21
hi mate, have you got any of the brakes left? also is it ABS or non ABS ? looking to upgrade my ES to vented fronts, all i really want/need are the front carriers as new calipers are not that badly priced
cheers!
Posted: Fri May 27, 2016 10:43 pm
by jamesy12345
cranna21 wrote:hi mate, have you got any of the brakes left? also is it ABS or non ABS ? looking to upgrade my ES to vented fronts, all i really want/need are the front carriers as new calipers are not that badly priced
cheers!
nothing left mate other than that short list above, sorry
Posted: Sun Jun 05, 2016 4:28 pm
by jamesy12345
Photos of boot/fuel lid release cover for dcwalker
Ends of bolt hole sleeves are damaged but not visible from outside
Posted: Mon Jun 06, 2016 8:29 am
by dcwalker
Thanks for going to that effort James.
TBH that one's much the same as the one I have, so I'll leave it I think...thanks anyway!
All the best
Posted: Mon Jun 06, 2016 9:33 am
by jamesy12345
dcwalker wrote:Thanks for going to that effort James.
All the best
no worries at all David, cheers
Posted: Thu Jul 14, 2016 8:53 am
by SamH
Hi Jamesy,
Do you still have the dashboard surround available please?
Sam
Posted: Tue Jul 19, 2016 2:58 pm
by jamesy12345
I will check Sam it might have gone already
Posted: Thu Oct 27, 2016 8:15 am
by jamesy12345
jamesy12345 wrote:I will check Sam it might have gone already
Forgot about this - I still have it if you want it Sam...!
