2 pipes
2 pipes
Post by Norm57 » Tue Jan 25, 2022 6:11 pm
Hi all I need the two pipes marked with white crosses if anyone can help?
malkontent
Re: 2 pipes
Post by malkontent » Tue Jan 25, 2022 6:30 pm
Hi
If upper one is for Turbo , I have . Read the part number on it .
also have , for 2.0 l engine
Re: 2 pipes
Post by Norm57 » Tue Jan 25, 2022 8:09 pm
Many thanks for reply and offer.I can get both from the Netherlands but am trying to source in the UK initially to avoid dreaded import duties. Cheers Norman.
Re: 2 pipes
Post by jamescarruthers » Tue Jan 25, 2022 10:07 pm
Hey Norm, you may need to clarify which engine you have to get the right one. Early cars have an oval throttle body; later ones circular; and maybe other variations depending on pipes and sensor.
Can you put your VIN number up?
Re: 2 pipes
Post by Norm57 » Tue Jan 25, 2022 10:49 pm
Thanks James. It’s for R3 which is a 1988 1.7 na the earliest engine I believe with the oval throttle body.
Re: 2 pipes
Post by jamescarruthers » Wed Jan 26, 2022 9:24 am
Ah, so a bit harder to find. I take it yours has a leak? I think you’ll have hands covered in RTV sealant soon!
Re: 2 pipes
Post by Alan 480 » Wed Jan 26, 2022 5:50 pm
IMHO self amalgamating tape might be neater and last a wee bitty longer?
stretches much better than gaffer/ insulting / carpet tape and at least it has some integrity initially?
