Subframe bushes
Subframe bushes
Post by jamescarruthers » Sat Oct 13, 2018 3:58 pm
There are two types of subframe bushes, two in the front (P/N: 3467815) and two in the rear (P/N: 3485813).
The rear ones seem to be very difficult to get hold of.
The front ones are available very easily and I think that you can make them fit the rear position, although that may be only true for later cars where I think the parts catalogue has 3467815 listed as suitable for installation front and back.
However, the rear (white) ones are available here: https://www.volvo340onderdelen.nl/en/vo ... 85813.html
I used these in my 480, however, check your subframe as later cars might just use all four of the easy to find ones!
Last edited by jamescarruthers on Sat Oct 13, 2018 4:09 pm, edited 1 time in total.
Re: Subframe bushes
Post by Alan 480 » Sat Oct 13, 2018 4:06 pm
James
you need to re-read your post :wink:
which ones can you easily get . . . . .. :?
Re: Subframe bushes
Post by jamescarruthers » Sat Oct 13, 2018 4:09 pm
James
Edited, thanks mate!
Re: Subframe bushes
Post by Alan 480 » Sat Oct 13, 2018 4:13 pm
James
no problem, I have a full set here (two front & two rear), mines a 93 car (built around july/august 93 if I go by various 'checked by tags /stickers' on cable harness, bonnet moulding etc and other parts etc
length of steel tube seems to be main difference?
Re: Subframe bushes
Post by jamescarruthers » Sat Oct 13, 2018 4:32 pm
Maybe its as simple as the length of the bar, yes. I was worried that the rubber might have been a different density front to rear (hence why the rears are white) so made sure I got the white ones
