Ebay: 2.0 S M652 SUD
Posted: Mon Oct 18, 2021 12:45 pm
Linky
Jiff's summary:
No interior shots.
"One minor fault only - mileometer needs replacing" - and has need it doing since 2015...
"Always been garaged" - Even photo'd outside a garage! It won't, of course, physically FIT in that garage, and the rear lights tell a different tale...
"MOT til Dec 2021 - has always flown through" Except in 2006, 2007, 2011, 2012, 2014, 2015, 2018 2019 and 2021.....
result: Smells like a wannabe dealer to me.
Re: Ebay: 2.0 S M652 SUD
Posted: Mon Oct 18, 2021 7:43 pm
by brinkie
Seller has one (1) feedback...
Posted: Tue Oct 19, 2021 6:24 pm
by Martin Mc
It is a nice colour, and they do polish up well. If the seller really has owned it for the past 15 years as they claim, I would guess there would be a decent pile of invoices / bills to pore over.
The MOT history isn't too bad, and the mileage doesn't seem to have been excessive at any point.
Date tested
6 January 2021
PASS
View test certificate
Mileage
70,016 miles
MOT test number
5845 8917 7291
Test location
View test location
Expiry date
5 January 2022
Monitor and repair if necessary (advisories):
Oil leak, but not excessive engine oil (8.4.1 (a) (i))
Nearside Front Suspension arm pin or bush worn but not resulting in excessive movement front bush starting to unbond (5.3.4 (a) (i))
What are advisories?
Date tested
11 December 2019
PASS
Mileage
70,016 miles
MOT test number
3591 2049 4975
Test location
View test location
Expiry date
10 December 2020
Date tested
27 November 2019
FAIL
Mileage
70,016 miles
MOT test number
8090 6944 1609
Test location
View test location
Repair immediately (major defects):
Offside Front Coil spring fractured or broken (5.3.1 (b) (i))
What are defects?
Date tested
5 December 2018
PASS
Mileage
70,016 miles
MOT test number
3099 5405 2566
Test location
View test location
Expiry date
6 December 2019
Date tested
26 November 2018
FAIL
Mileage
70,016 miles
MOT test number
6091 4698 6281
Test location
View test location
Offside Brake cable insecure (1.1.15 (c))
Emissions not tested (8.2.1.2 (d))
What are defects?
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor. Find out more
Date tested
1 December 2017
PASS
Mileage
70,016 miles
MOT test number
1435 0385 2146
Test location
View test location
Expiry date
6 December 2018
Date tested
28 November 2016
PASS
Mileage
70,016 miles
MOT test number
3130 2638 1106
Test location
View test location
Expiry date
6 December 2017
Date tested
3 December 2015
PASS
Mileage
70,016 miles
MOT test number
8373 5725 0655
Test location
View test location
Expiry date
6 December 2016
Date tested
30 November 2015
FAIL
Mileage
70,016 miles
MOT test number
4370 4738 2415
Test location
View test location
Reason(s) for failure
Nearside Rear Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
Registration plate lamp not working (1.1.C.1d)
Advisory notice item(s)
Exhaust has a minor leak of exhaust gases (7.1.2)
Nearside Front Brake pad(s) wearing thin (3.5.1g)
rear brake discs slightly corroded
What are failures and advisories?
Date tested
28 November 2014
PASS
Mileage
69,709 miles
MOT test number
4756 5233 4476
Test location
View test location
Expiry date
6 December 2015
Nearside Rear Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
Date tested
2 December 2013
PASS
Mileage
69,226 miles
MOT test number
6191 3663 3327
Test location
View test location
Expiry date
6 December 2014
Date tested
7 December 2012
PASS
Mileage
68,772 miles
MOT test number
4773 9284 2475
Test location
View test location
Expiry date
6 December 2013
Date tested
5 December 2012
FAIL
Mileage
68,772 miles
MOT test number
8982 6044 2364
Test location
View test location
Horn not working (1.6.2a)
Nearside Anti-roll bar has excessive play in a pin/bush (2.4.G.2)
Exhaust system not adequately supported (7.1.1)
What are failures?
Date tested
13 November 2012
FAIL
Mileage
68,772 miles
MOT test number
7074 1801 2356
Test location
View test location
Emissions not tested (7.0)
Rear registration plate deteriorated but not likely to be misread (6.3.1d)
Date tested
26 November 2011
PASS
Mileage
68,513 miles
MOT test number
7597 6073 1342
Test location
View test location
Expiry date
25 November 2012
Date tested
27 October 2010
PASS
Mileage
67,085 miles
MOT test number
5601 6060 0343
Test location
View test location
Expiry date
29 October 2011
Date tested
30 October 2009
PASS
Mileage
66,423 miles
MOT test number
6723 1300 9315
Test location
View test location
Expiry date
29 October 2010
Date tested
18 October 2008
PASS
Mileage
64,880 miles
MOT test number
2445 6249 8215
Test location
View test location
Expiry date
27 October 2009
Date tested
20 October 2007
PASS
Mileage
63,952 miles
MOT test number
3025 3389 7217
Test location
View test location
Expiry date
27 October 2008
Date tested
28 October 2006
PASS
Mileage
62,748 miles
MOT test number
2605 9110 6370
Test location
View test location
Expiry date
27 October 2007
Nearside Front Track rod end ball joint has slight play (2.2.B.1f)
Offside Front Track rod end ball joint has slight play (2.2.B.1f)
Nearside Front Anti-roll bar rubber mounting deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Front Anti-roll bar rubber mounting deteriorated but not resulting in excessive movement (2.4.G.2)
Date tested
11 October 2006
FAIL
Mileage
62,544 miles
MOT test number
3936 5478 6496
Test location
View test location
Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
Nearside Track rod end ball joint has excessive play (2.2.B.1f)
Offside Track rod end ball joint has excessive play (2.2.B.1f)
Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
rear registration plate slightly deteriorated
