Ignition barrel
Ignition barrel
Post by Norm57 » Fri Aug 06, 2021 7:45 am
Hi all I am needing an ignition barrel and key for R3. If anyone has one or knows of one going spare I would be grateful. Thanks Norman
Re: Ignition barrel
Post by jifflemon » Fri Aug 06, 2021 10:31 am
wont be the barrel and key, there's a white plastic bit on the back you can swap. Held in with a tiny allen key...
Lemme hunt, I did find somewhere online that was selling them.
Edit: here - currently out of stock though
Edit2: You may be able to pull it apart and clean it up - had to do similar for another member, as his car would go "dead" when turning the key.
Its a little bit fiddly, but doable.
