Two Tone for sale in Wallington, £1,750
Post by MisterH » Fri May 14, 2021 4:11 pm
https://www.ebay.co.uk/itm/284293431080 ... 1111.m2109
This one has the dismal engine, needs arch repair and seat retrim, but for a running, driving car this one seems for once, to be at a reasonable price :eek:
Rob88h
Re: Two Tone for sale in Wallington, £1,750
Post by Rob88h » Wed Jun 16, 2021 1:55 pm
This one has popped up in a couple of YouTube video's. I thought I recognised the reg...
He's named it Khujo, like Hugo, but in Swedish.
https://www.youtube.com/watch?v=3DfTQMwGXZw
https://www.youtube.com/watch?v=GCd4x3PIVj0
https://www.youtube.com/watch?v=fwE_AiYtffg
100
Post by 100 » Wed Jun 16, 2021 3:00 pm
Hey! I have that engine!
It's not really dismal, just a bit dismal.
Post by jifflemon » Wed Jun 16, 2021 9:38 pm
this is the car that he won for £10, then destroyed the head gasket on the way home, after driving with no temp gauge on the info centre and suffering water pump failure.....
Post by MisterH » Thu Jun 17, 2021 2:23 pm
Are you able to get de-cat on that or is it a year too late?
Post by jifflemon » Thu Jun 17, 2021 2:29 pm
anything 93 onwards needs a cat
Post by dragonflyjewels » Thu Jun 17, 2021 3:42 pm
Thort it was 92 ? Lily is late 91 and I was told only just old enough to de-cat ?
Post by Jay-Kay-Em » Thu Jun 17, 2021 4:14 pm
[geek mode]
The MoT "cat test" starts for cars registered post 1st August 1992 - with exemptions.
It is mandatory for all cars registered after 1st August 1995 to pass this test.
Between 1st August 1992 and 1st August 1995 there is a grace period for some cars.
Basically, some low volume manufacturers didn't pull their socks up in time and applied for cat test exemption as their designs weren't ready. It was agreed this exemption would run out by 1st August 1995.
Whether your car is included in this three year window for a cat test is determined by the following publication HERE which is up to the 19th edition and the MoT tester must check.
If you have trouble sleeping, it is a perfect bedtime read.
All 480's are listed in this publication by engine code which means our date for cat testing is 1st August 1992 across everything.
My TVR was registered December 1992 (so post the August introduction) and was never fitted with cats from factory. It is not found 'in the bible' so has exemption. It was precisely the car the three year window was designed for as TVR were a bit rubbish with regulations :rofl:
[/geek mode]
Post by dragonflyjewels » Thu Jun 17, 2021 5:57 pm
:bored: :bored: :bored:
Post by dcwalker » Thu Jun 17, 2021 6:37 pm
:rofl:
although I must secretly admit Jay, that's quite interesting, thanks!
Post by jifflemon » Thu Jun 17, 2021 8:32 pm
:rofl:
The other bit is that the match needs to be EXACT.
So, if you had, as an example, a 1994 480 with a 2.0 16V engine transplanted in it, well, there's no match, because it never existed so it's back to the "old" emissions test figures (3.5% CO, 1200PPM HC).
Post by Alan 480 » Fri Jun 18, 2021 4:58 pm
I just use K = Kat reqd, :D
need to investigate the loop-hole as to what makes it 'not exact' :rofl:
