Ebay: ES J106 LRL
Ebay: ES J106 LRL
Post by jifflemon » Thu Apr 08, 2021 9:48 pm
Nice arch repair
Seriously, what is wrong with some people? :angry:
Re: Ebay: ES J106 LRL
Post by edie_fox » Thu Apr 08, 2021 10:12 pm
Poor car. :cry:
Post by jamescarruthers » Fri Apr 09, 2021 6:20 am
:shock:
Chequer plate is appalling even on a Land Rover never this poor two-tone! Imagine if it has perfect arches and he just likes glued on tat?!
Post by Martin Mc » Fri Apr 09, 2021 8:14 am
It is 'Gunthered' (technical term). I'm going to ask for more photos and a bit more information about the 'enhancements' that have been made to the car. Will report back if I get anything that I can translate adequately from Neanderthal...
Post by Martin Mc » Fri Apr 09, 2021 8:20 am
It appears to be a relatively low mileage example :wink: - below info from the Gov.uk website..
J106LRL VOLVO 480
Check another vehicle
Colour Blue
Fuel type Petrol
Date registered 17 June 1992
MOT expired on 25 August 2017
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal. (Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA.
Check mileage recorded at test, MOT expiry date, defects and advisories, and view test certificate
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor. Find out more
Date tested 26 August 2016
Pass
Mileage 69,536 miles
MOT test number 9672 1672 6624
Test location
View test location
Expiry date 25 August 2017
Advisory notice item(s)
Nearside Rear coil spring corroded (2.4.C.1b)
Offside Rear coil spring corroded (2.4.C.1b)
Offside Rear Brake pipe slightly corroded (3.6.B.2c)
What are advisories?
Date tested 23 August 2016
Fail
MOT test number 6253 1773 9063
Test location
View test location
Reason(s) for failure
Parking brake: efficiency below requirements (3.7.B.7)
Nearside rear parking brake recording little or no effort (3.7.B.6a)
Offside Front Shock absorber has a serious fluid leak (2.7.3)
What are failures and advisories?
Date tested 25 August 2015
Pass
Mileage 66,651 miles
MOT test number 6167 0383 6163
Test location
View test location
Expiry date 24 August 2016
Offside Rear Shock absorber has a light misting of oil (2.7.3)
Date tested 10 August 2015
Fail
MOT test number 3095 4150 6003
Test location
View test location
Nearside Front Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
Offside Front Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
rear parking (secondary) brakes imbalanced (3.7.B.6b)
Offside Front Shock absorber has a light misting of oil (2.7.3)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
Date tested 9 June 2014
Pass
Mileage 65,767 miles
MOT test number 9594 1076 4193
Test location
View test location
Expiry date 8 June 2015
Nearside Front coil spring corroded (2.4.C.1b)
Nearside Front Brake pipe slightly corroded (3.6.B.2c)
Offside Front Brake pipe slightly corroded (3.6.B.2c)
Date tested 4 June 2014
Fail
MOT test number 8768 2535 4165
Test location
View test location
Nearside Headlamp aim too low (1.8)
Nearside Front Brake pad(s) less than 1.5 mm thick (3.5.1g)
Offside Front Brake pad(s) less than 1.5 mm thick (3.5.1g)
Nearside Rear brake disc in such a condition that it is seriously weakened (3.5.1i)
Offside Rear brake disc in such a condition that it is seriously weakened (3.5.1i)
Nearside Rear rear brake excessively fluctuating (3.7.B.3)
Offside Rear rear brake excessively fluctuating (3.7.B.3)
Nearside rear brake recording little or no effort (3.7.B.5a)
Offside rear brake recording little or no effort (3.7.B.5a)
Nearside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Date tested 25 January 2011
Pass
Mileage 59,899 miles
MOT test number 4075 3552 1022
Test location
View test location
Expiry date 30 January 2012
Date tested 21 January 2010
Pass
Mileage 58,449 miles
MOT test number 2647 2132 0041
Test location
View test location
Expiry date 30 January 2011
Date tested 22 January 2009
Pass
Mileage 56,957 miles
MOT test number 1747 0202 9024
Test location
View test location
Expiry date 30 January 2010
Date tested 21 January 2008
Pass
Mileage 55,650 miles
MOT test number 1815 3192 8091
Test location
View test location
Expiry date 30 January 2009
Exhaust has a minor leak of exhaust gases (7.1.2)
Date tested 13 January 2007
Pass
Mileage 53,974 miles
MOT test number 4730 9321 7019
Test location
View test location
Expiry date 30 January 2008
Date tested 12 January 2007
Fail
MOT test number 7835 7251 7096
Test location
View test location
Parking brake lever has no reserve travel (3.1.6b)
What are failures?
Date tested 31 January 2006
Pass
Mileage 53,175 miles
MOT test number 3512 6183 6027
Test location
View test location
Expiry date 30 January 2007
Post by dragonflyjewels » Fri Apr 09, 2021 9:41 am
O dear, the tat is probably hiding rust and stone chips. MoT history doesn't look frightening. Looks in need of rescue to me ! Anyone near enough to go and check it out ?
Post by Martin Mc » Fri Apr 09, 2021 10:01 am
Reply hot off the press from the seller on eBay...
New message from: 2011sarahc1983 (773)
Hi the cracks on the first picture, on the drivers side, and the wheel archers are all good yes, the interior not bad condition, but it needs the bar fixing back on under drivers seat, and yes the car starts but some times u may have to turn key before power goes to the engine, Don't no why that is but it does starts and yes it drives, but there is a delay in the stopping time when you put the brake pedal down, it might just need bleeding am not sure, but I wouldn't recommend driving it! till the brakes are fixed!
To be fair it was a quick reply, and addressed all of the points I'd asked for clarification. Seller appears to be a bona-fide eBayer
Still, £500 for a gunthered example is a bit saucy! :kill:
Post by Martin Mc » Fri Apr 09, 2021 10:11 am
I may be in Sheffield in the next couple of weeks, but probably not before the end of this auction.. It is a 2 hour drive for me, so unlikely to happen just to see this car, which is a shame..
Post by jifflemon » Fri Apr 09, 2021 2:22 pm
I wonder whether the chequer plate is actually "stick-on" chequer plate, rather than actual metal chequer plate....
Post by Martin Mc » Fri Apr 09, 2021 7:05 pm
Some more photos, courtesy of the very obliging seller...
Looks like the cambelt was last done in 2010 around 58K miles...
Boot cover missing or covered with some hideous fablon
'Normal' wear to seat bolster, non-airbag steering, clean enough looking cockpit, door pockets intact -
DEFINITELY WORTH SAVING THEN!!
I've asked for some close up pics of the rear arches and underside, which may arrive tomorrow... Watch this space!
M
Post by jifflemon » Fri Apr 09, 2021 7:57 pm
we've asked similar things.... prepare to be disappointed...
Me: Do you have pictures of the rear arches? Is that Chequer plate metal or just stick on graphics?
Seller: Its Metal Checker plate protection for it that will last as long the car lasts!
Me: Do you have pictures?
Seller: You can see its metal
Me: Yes, but I'd want to remove it. So wondering what the metal underneath it is like?
Seller: Its ok! but you will need to fill the holes in were the checker plate is screwed down! Then spray it, its Up 2 u like!
:angry: :badmood:
arthuy
Post by arthuy » Fri Apr 09, 2021 9:37 pm
just realised the checker plate in in the headlamps.
Must be a very thin plate or stick in faux plate.
looks like a tidy car too.
Post by jifflemon » Fri Apr 09, 2021 10:25 pm
And the bonnet! Why given that both the bonnet and lamp covers are fibreglass..... :wall:
Post by dragonflyjewels » Sat Apr 10, 2021 7:53 pm
We have to go to Leeds on Thursday, so I've arranged to call in and look at this on the way. (This is always assuming I do actually get an address !) Seller isn't there til 5pm, so if anyone is interested in bidding pm me your mobile no. so I can text my observations before the auction ends.
Post by jamescarruthers » Sat Apr 10, 2021 7:59 pm
Please can you take a psychiatrist with you. The chequer plate is clearly a cry for help.
Post by dragonflyjewels » Sat Apr 10, 2021 8:13 pm
All I see is a car that desperately wants to be released from wheel arch hell ! I suspect the seller is beyond help...
Post by jamescarruthers » Sat Apr 10, 2021 8:20 pm
wheel arch hell !
:lol:
Van
Post by Van » Sat Apr 10, 2021 9:11 pm
... but some times u may have to turn key before power goes to the engine...
Isn't it always like that? My 480 never would automagically start without turning the key.
Post by dragonflyjewels » Mon Apr 12, 2021 8:03 am
Gone !! Presumably someone waved a bundle of notes under the seller's nose, just hope it wasn't a breaker
Post by brinkie » Mon Apr 12, 2021 9:45 am
Not sold through eBay as it shows 0 bids. Hope it doesn't turn up at a crooked seller. A very dilapidated example of a 480 (but with valid MOT and "recent" service) was sold here for 500 and snapped up by a very nasty wannabe dealer, who managed to sell the car for 1500 to a hapless victim. It is astonishing how many people don't do their research before buying such a car.
