Look who's back up for sale
Post by jifflemon » Mon Dec 07, 2020 11:22 am
https://mathewsons.co.uk/auctions/aucti ... -480-turbo
New owners not had it longer since they bought it....
We discussed it at length here
I said avoid it then, I maintain that position now!
cranna21
Re: Look who's back up for sale
Post by cranna21 » Mon Dec 07, 2020 11:36 am
There's something about this Turbo that i really like - i think its just the simple colour, stripe combo
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
Post by dcwalker » Mon Dec 07, 2020 11:44 am
Hmmm...trouble is, we identified a whole load of stuff NOT to like about this turbo :lol:
And the fact it has come around for sale again so quickly definitely rings the alarm bells, to me, anyway.
If I can find time and opportunity this week I am going to go and look at it. Not interested in it myself but I'll try to return and post a fair report so anyone who is interested knows a bit more.
cranna21
Post by cranna21 » Mon Dec 07, 2020 11:53 am
Sorry, I'll re-phrase... :lol:
if it was less than £1000 there would be something about this Turbo that i really like - i think its just the simple colour, stripe combo! :rofl:
Post by dcwalker » Mon Dec 07, 2020 12:29 pm
:rofl: :rofl: well done!
Post by dragonflyjewels » Mon Dec 07, 2020 1:44 pm
It looks a lot nicer than its MoT history :lol:
If it was donated to the rescue group it would be a hard decision on whether to break or rescue it
cranna21
Post by cranna21 » Mon Dec 07, 2020 2:49 pm
I'd 100% be stupid enough to Rescue it haha
Post by Jay-Kay-Em » Mon Dec 07, 2020 4:43 pm
Bonhams auction (the previous sale) states sold for £2,475 :shock:
Perhaps it was purchased solely for the offside front Taurus centre cap which is now missing since Bonhams :lol:
Post by MisterH » Mon Dec 07, 2020 5:40 pm
:lol: :lol: :rofl: :lol: :lol: :lol: :rofl:
Looks like we have a hot potato...
Post by Norm57 » Mon Dec 07, 2020 9:44 pm
If anyone is interested there is a video that Matthewsons have done for the auction. Something about this car just doesn’t feel right? I have serious doubts about the mileage after viewing the video. The wear and tear in the cabin tells me it’s a high mileage vehicle. Both rear arches are decaying,cracked rear lenses,and it sits lopsided ,after market silencer,rust stains on the carpets,overall I rate it £500 maximum on a good day.
Post by jifflemon » Mon Dec 07, 2020 10:09 pm
just to remind everyone of the previous miracles performed on the car....
brinkie wrote:
Thu Jul 09, 2020 1:31 pm
No MOT currently, and given the list of defects the car failed two subsequent MOTs (one month apart - listing some of the same defects) makes it very unlikely to get it MOT'ed without major investments.
Date tested 15 May 2020
FAIL
Mileage 56,234 miles
Do not drive until repaired (dangerous defects):
Front Steering component mounting prescribed area is corroded to the extent that control of the vehicle is likely to be adversely affected subframe corroded near steering rack mount (2.1.2 (e) (ii))
Front Sub-frame insecure and impairing directional stability sub frame corroded (5.3.3 (a) (ii))
Repair immediately (major defects):
Offside Rear Seat belt buckle missing (7.1.2 (d))
Offside Rear Seat belt anchorage prescribed area strength or continuity significantly reduced inner wheel arch and outer sill (7.1.1 (a) (i))
Offside Windscreen damaged and affecting the driver's view of the road (3.2 (a) (ii))
Nearside Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
Offside Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
Offside Front Position lamp not working (4.2.1 (a) (ii))
Headlamp aim not tested head lamp mech not rising headlamps to position (4.1.2 (b))
Headlamp not working on dipped beam head lamps not rising to position when switched on (4.1.1 (a) (ii))
Hazard warning switch inoperative (4.4.2 (a) (ii))
Hazard warning lamps inoperative all lamps (4.4.1 (e))
Nearside Front Direction indicator not working (4.4.1 (a) (ii))
Offside Front Direction indicator not working (4.4.1 (a) (ii))
Emissions not tested unable to run engine at steady revs and part of in take system missing (8.2.1.2 (d))
Emission control equipment missing where fitted as standard maf sensor disconnected and intake pipes missing (8.2.1.1 (a))
Oil leaking excessively from engine sump plug area (8.4.1 (a) (i))
Offside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength inner wheel arch and outer sill (5.3.6 (a) (i))
Offside Front Sub-frame corroded and seriously weakened (5.3.3 (b) (i))
Nearside Front Brake hose excessively deteriorated (1.1.12 (b) (ii))
Offside Front Tyre fouling a part of the vehicle inner wing and brake hose (5.2.3 (f))
Brake performance not tested due to condition of front sub frame unsafe to carry out brake test (1.2.1 (g))
Repair as soon as possible (minor defects):
Hazard warning switch insecure (4.4.2 (a) (i))
Offside Registration plate lamp inoperative in the case of multiple lamps or light sources (4.7.1 (b) (i))
Offside Front Brake hose slightly chafed (1.1.12 (b) (i))
Monitor and repair if necessary (advisories):
Offside Front day time running light inop
Offside Front Tyre slightly damaged/cracking or perishing perished (5.2.3 (d) (ii))
Nearside Rear Tyre slightly damaged/cracking or perishing perished (5.2.3 (d) (ii))
Offside Rear Tyre slightly damaged/cracking or perishing perished (5.2.3 (d) (ii))
Date tested 18 June 2020
FAIL
Mileage 56,241 miles
Nearside Front Suspension arm ball joint likely to become detached Split pin missing (5.3.4 (a) (ii))
Offside Front Suspension arm ball joint likely to become detached Split pin missing (5.3.4 (a) (ii))
Offside Rear Rear fog lamp not working (4.5.1 (a) (ii))
Offside Rear Inner Seat belt anchorage prescribed area strength or continuity significantly reduced Arch (7.1.1 (a) (i))
Offside Rear Seat belt missing Stalk (7.1.2 (a))
Brake pipe excessively corroded Across the rear frame (1.1.11 (c))
Nearside Front Brake hose bulging under pressure (1.1.12 (d))
Parking brake efficiency below requirements (1.4.2 (a) (i))
and yet less than a month later, it not only passed, but passed with ZERO advisories... :roll:
Post by Alan 480 » Tue Dec 08, 2020 1:40 pm
did the MoT guy do a 'virtual' MoT???, maybe a Zoom meeting where they showed them the number plate then a different car.
surely the second MoT station could have it's ticket removed by VOSA?
There is a 'possibility' that all work had been done, but seven miles between the two fails, then not many more and it 'passes' ? :?
PS noticed that every one is at different MoT stations :hopping:
but to be fair the list does seem to get less as the MoT progresses, but if mine fails, I'd fix and go back to same place as then they will only CONCENTRATE on the items that failed previously?
Post by jifflemon » Tue Dec 08, 2020 2:47 pm
Appealing an MOT isn't as straightforward as it should be.
For maximum effect you want it as close as possible to the original test date and with as few miles as possible covered.
Even corrosion only has a 3 month window.
Post by brinkie » Wed Dec 09, 2020 8:37 pm
Don't know how it works for MOT, for APK (Netherlands) you pay 20-30 € for the test, many workshops offer it to do for free if you combine the APK with service maintenance. If it fails APK they will fix the defects (unless it's really bad and expensive - then it's up to the customer) and then you get "passed after repairs" on the form. But I don't want them to repair my car, so I'll pay the 20 euro and ask them to register it as a fail. Then the fearmongering starts, "you are not allowed to drive the car anymore until it is repaired" which is technically true, but a fail isn't registered, it's just a legal document that they haven't issued you a pass and you are entitled to contest their decision. The APK expiry date doesn't change and the police won't stop you unless your car shows very obvious defects. Also, if you repair the car yourself or have it repaired by someone else, you can have a free retest in 2 weeks. When a car fails on a loose fog light I can very well repair that myself. ;)
Of course I won't drive it when there is serious fail involving safety, but last time the local workshop tried to scam me into 600 Euro of repairs, claiming tie rod ends, track rod ends and control arms had torn rubbers and the shock absorbers were bad. I didn't believe them, as all these parts were just 4 years old (less than 10,000 miles driven) so I took it out of their hands and went to my trusted specialist who lives an hour away. Turned out that just the rubber grommets of the tie rod ends were on its way out (5 euro each) and they also didn't use a new ring for the oil drain plug, so it was very much marking its territory. Didn't even bother for a free retest, paid the guy who serviced the car properly for a test and never went back, never paid the local garage for the APK and the oil and they've never sent me a bill (though they have my address and phone number) so they knew they were trying to scam me.
Helmert3
Post by Helmert3 » Wed Dec 09, 2020 9:18 pm
I was actually going to post that I saw this one pop up. I take it after just a breif glance at the other thread that this one isnt worth anyones time?
Post by jifflemon » Wed Dec 09, 2020 9:38 pm
I wouldn't touch it with someone else 6ft barge pole...
Helmert3
Post by Helmert3 » Wed Dec 09, 2020 10:07 pm
And so my search continues :rofl:
Post by Alan 480 » Thu Dec 10, 2020 3:57 pm
we could 'present' for an MoT one month prior to expiry date and if it failed then at least you still had a 'piece of paper' to show the Police :-)
but now it's 'online' and with the ANPR system they could catch you out.
even used to get a 'ticket' and with a wee note saying 'fix this/that' as they knew i would that week-end, ah the old days :wink:
Post by dcwalker » Thu Dec 17, 2020 6:10 pm
According to Mathewsons' website, this has sold:
Anyone on here willing to own up? :lol:
Post by jifflemon » Thu Dec 17, 2020 6:26 pm
No way to find out how much for?
