Footwell lighting!
Posted: Fri Jul 05, 2013 10:12 pm
I fixed the bulb for the ignition ring today with a new green LED and decided to start to install some footwell lighting at the same time.
I fitted a 12smd LED strip under the drivers side dashboard and connected it to the connectors on the ignition ring light so that it works on the courtesy circuit.
It's all fully reversible in case I didn't like it but I think it works great and I'm going to do the passenger footwell too.
EDIT - If anybody want's a light strip or two to add footwell lighting I can supply a 12SSMD strips with attached lengths of wire for £5.99 each.
