Engine and Brake caliper Paint
- esta
Hey there
Looking to paint my brake calipers (red) but i do not know much about which brands are good and which ones aren't. So please does anyone know what make they would recommend, how much it is and how far that goes (eg can for £10 does 2 calipers) and also where its from.
Thanks in advance
Thanks in advance
HAVE: Jaguar XJ40 4l Sov
www.projectjaguar.co.uk
- esta
I read somewhere that Hammerite does the trick? Is this really suitable for the job? Also thanks for the sandblasting advice, but will a wire brush do the job? And how long before i can use the brakes again...? Although i may just go for the Halfords Own Brand like you said you used...so no probs then? Dry quick?
Sorry for all the inquest lol
- esta
I am imaging that the thinners in Dutch is the same for English because all of the cans say use thinners...but your calipers do look good so i will be using thinners too
Also in Halfords they had one can for calipers and one for engines...since both get red hot, i am presuming that either can be used for both? (I am planning to buy some engine paint in a can to do both tomorrow unless someone informs me otherwise...)
Thanks all for saving me from my usual rushing in and messing up big stylee!
- Dan the 480 Man
- esta
Well they have been done with the Halfords own HI Temp paint...only time will tell i guess...and thanks for all the advice
- SMOOTH 480
i work in a marine engineering company we use suncorite black paint this is good for a primer as it bonds with the metal and stops rust i painted my calipers with 2 coats and then detailed the volvo emblem in a nice marine spec yellow paint they've survived for four months now with jet washing
if this option cant be achieved then hammerites smoothrite is the only other paint i would use on calipers and intake manifolds
1985 celicasupra ( Project )
member 3285
member 3285
- eEm
Sand/grit blasting and electroplating shouldn't cost more than £10 for both calipers if you take them to a classic car restorer. I've had the subframe, wishbones, trailing arms, stub axle carriers, calipers and induction done for about £50. With a free coat of zinc-oxide primer or electroplate for free on all of it.
Wire brush will take you ages and won't give you a uniform finish for painting like sandblasting will. Shop around, I was quoted £250-400 just for the subframe till I called a classics restorer and he did it for £25 with zinc oxide primer!
Definately worth it.
Why won't God heal amputees?
- SMOOTH 480
if you do go the route of sand blasting make sure they have sufficient masking around the pistons to stop the grit/sand
any unwanted sand in the brakes and your in trouble
member 3285
member 3285
- SMOOTH 480
certainly m8
here you go black calipers with yellow detailing
member 3285
member 3285
- esta
Ooo good job, very sophisticated! Forgot to look when we were at that meet-duh!
- SMOOTH 480
not that you can see it when the rims are on but i know its there
member 3285
member 3285
ROFL, I did mine in red just so it would not look like Im too cheap for brembo calipers.finished in 'wish I could afford Brembo customs-red'!
MatBat's 944S2 calipers are 6 pot's and massive!
I always laugh at pictures of Vader with her 17's a shitty little calipers but really the front calipers on the 480turbo do a super job with good pads and disks. I had looked many times and even had details of fitting brembos but it's a load of cash and I'm happy now to say you don't need them but having SS lines does make it feel better.
