Engine strength
Engine strength
Hello everyone!
I am the owner of a 340 with a 440 turbo engine. I need some info on the strength of the b18ft engine, mine is running at 1 bar, with a t3 turbo, mildly ported head and aftermarket management. I am currently getting 220 bhp and 230 lbs/ft torque, What I want to know, is how far in terms of boost pressure/power out put, can you take one of these engines before they fall apart? I have examined the guts of it, and personaly I feel tthat the rods will be the first thing to let go, but I dont want to find out by destruction testing! any info would be appreciated
Iain
Iain
340 turbo
- Murf
Your reputation preceeds you!
http://volvo480.northernscum.org.uk/for ... php?t=7248
richard is getting 250 bhp, as far as i know he had standard engine internals with a bigger turbo, V6 injectors and other stuff.
what are you using, clutch wise, and is it handling the power?
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
1992 480 Turbo
2007 Focus ST
I am using a clutch built by techniclutch on a later 220 mm flywheel, nothing too trick, just uprated cover plate and stronger springs in the centre plate. Had to go this way as I have to have a centre plate with 340 spline size, when I first built the car I used a 440 turbo(200mm) cover plate with a 340 std centre plate which lasted quite well (up to about 180 bhp) I recon 250 bhp is ok on stock internals, but I think much more is going to bend/ break the conrods as there very spindly around the small end, I have run 1.2 bar briefly with no problems, I should think that was making around the 240 mark but I dont want to go above this untill I know more about the limitations of the stock setup
340 turbo
- tobi480turbo
Hi,
as Martin said ~250Hp should be more or less the limit of the stock setup as infact of thermal and mechanical stress.
I´m runnig a B20F(T) engine with arround 1.4bar and it´s working well so far
the only problem I have is the clutch at the moment
I´m already running an uprated clutch from sachs which was meant to be good for arround 300Hp but when fully accelerating it starts slipping.
Can you probably tell a little bit more exact what kind of clutch you´re running and what had to be done ? it also would be useful to know how much it had cost and where you bought it ?
As I wrote in some other threads I think I´m running arround 250-270Hp at the moment but haven´t had the time and money to get it Dynod like it is at the moment to see how much power and tourque the engine has at the moment.
And nice to see you at the board !
Regards
Tobi
Regards
Tobi
I had 25psi on my T25 but the auto just wont take it very well. I'm on 15psi (once it stops boost leaking)
Gonna hook my g/b cooler up to with a cooler supply of water to keep it cooler and stop cooking it all.
My piston also melted when the damn injector went lean I do have a 2 bar map sensor but i'm back to the 170 mod so it's not in use.
- tobi480turbo
Hmmm,
you still have the auto problem and the temp ? doesn´t sound that nice
Do you plan to use the 3bar sensor again the next time or do you probably want to sell it, or exchange it with the 2.5bar version I have ? ( just an idea )
Regards
Tobi
Regards
Tobi
@Tobi
The clutch I currently use is made by a company called Techniclutch, WWW.techniclutch.com 0800 0834142. the clutch they did for me is for a 220 mm flywheel, which is a straight swap for the 200mm that I had originaly. It has an uprated pressure plate, and a heavy duty organic lining on the centre plate with stronger springs in the centre. It is lighter to use than the A.P. 200mm stock cover plate I used to use, and is supposedly capable of coping with 300 lbs/ft torque. so far I have had no problems. It cost me a very reasonable £130, although I think that is a slightly discounted price
Does anyone have a picture or any info on the 400 diesel con rod?
If anyone is about this sunday, I am going up to santa pod for some quatermile action, would be good to not be the only one there with a volvo!
Iain
Iain
340 turbo
- tobi480turbo
Hi!
thx for the info !
I´ll se what I´m going to do about the clutch ... if I remember right my uprated clutch should be good for ~450Nm and ~300HP .. also with uprated springs and organic centre plate ... so there are 2 possibilities, the clutch isn already used to much ( 20.000km ) or I´ve more than 450Nm of tourque. Hope to find a solution the next time cause it doesn´t make that much fun driving with a slipping clutch :/
Tobi
thx for the info !
Tobi
- tobi480turbo
Hi Guys !
me again
today I was at the Dyno with my 480 to see how much I´ve gained so far, but something must have gone wrong there *hmpf
My A/F gauge was showing only lamda 1 ( green LEDs ) when full accelerating not like it should rich mixture ( 1st/2nd orange LED ).
Probably some problems with the cable connections or connectors, at the way home everyting was fine again, Ok I had unplugged/replugged the MAF and Throttle conector before driving home. Tomorrow morning I´m going to give it another run at the Dyno and hopefully then everythin is going to work OK ! Today´s results were ~330Nm of tourqe and ~ 190Hp, and here´s a pic from my 480 taken at the Dyno ... don´t look to accurate at the power and tourque graph ... they were looking ugly today over 3500rpm
hope to get some much better results tomorrow with everything working fine
Tobi
me again
Tobi
- Ettore Bugatti
- tobi480turbo
Hi again
update from todays results ... seems like everything was working fine today at the Dyno and the final results so far were ... ~200Hp and I think impressive 352Nm of torque at at boost pressure of 1.3bar going to try if I can get a little bit more of boost which should give some more Hp and some more Nm ... but the limit with the boost is at ~1.4bar with the MAP sensor I have at the moment
Tobi
Tobi
- Ettore Bugatti
Very nice! btw is it flywheel or wheel figures?
Makes me wonder what your 80-120kmh in IV gear is. About 5 seconds?
Is it easy to recalibrate the rpruen ECU for the different MAP sensor?
Rover Mini 1000, june 2009-
good figures Tobi, are you still using the stock throttle housing? I found this quite restrictive past about 180 bhp, How much boost does the car hold at high revs? from the torque curve from the previous dyno run it looked like it was tailing off. How big is the fan at the dyno? Sorry for all the questions, but I am a dyno operator so It's always interesting to see what other people are doing!
Heres a power graph for my car before the last couple of mods, the figures are at the flywheel.
340 turbo
- tobi480turbo
Hi Huskyracer
hmmm good questions you were asking
About the fan I don´t know exactly how big it is, but as I think it was ~1m or something in this size, haven´t had that much to do with dynos.
At the moment I´m running the engine with the standart 1.7L throttle body but I´ve the one from the 2L engine lying arround here somewhere ... so probably it´s worth a try again with this one.
The boost was at ~1.3bar at lower revs but than dropped to arround ~1.1bar as I had seen ( but could be wrong ). I´m going to play with the MBC the next few days to see if I can get the boost a little bit higher.
here´s a pic of the actual graph from the dyno run today:
it´s not that nice that the torque is going that much down at thigher revs
or why it has this ups and down at the mid rev ( ~ 3500/4000rpm ) section ?
Whish I had some guys arround here like you guys in the UK !
sadly I´m more or less on my own with my problems cause nobody is interested in doing/working at such an "old" car ... or nobody is used to it.
Regards
Tobi
Regards
Tobi
