Perfect power smt6
- Ettore Bugatti
Perfect power smt6
Well for the turbo guys, I was wondering of this product is usefull and of it worth its money.
Basical it a piggyback system, but can control extra controllers. It costs about 350 euro's. Im aware that RPruen's mod works, but I like the idea of having a standard ECU with additional injector to control extra boost
Anyway well here is the link:
http://perfectpower.canspeed.com/smt6.htm
greetz Richard
greetz Richard
- rpruen
That's interesting. It may actualy be of some use, it depends what It can do in the way of blocking signals from increasing over a particular range. I'm also not sure about the ignition signal, it may strugle with that, since the ring of teeth has a gap in it to fix the crank position, the ecu knows how many teeth if any go missing (when the unit changes the timing), then it will cause a missfire.
Unfortunatly It won't help with the MAP sensor, because it's inside the ECU itself. So it won't be able to remove the boost cut.
It would be intersting to see what this unit can do.
Richard
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
- 480 Veteran
- rpruen
Yep megasquirt and spark. It's a little add on that uses the existing hardware in MS. Unfortunatly it won't directly work on the 480.
It would be nice to have an add-on that will interface with the bosch flywheel sensor. Plus you then get to use the same setup as bosch to do the ignition timing.
Using a counter to count down using the edges of the teeth as a trigger, then a second stage using a hardware clock to get fine control over the timing. The great part is that the ecu cpu only has to output values into the counter circuit when it wants to change the timing. The hardware will use the gap in the ring to reset the counter, so without any input from the cpu the coil trigger signal will arrive at the set value. Changing the couters initial values allows the timing to be set as required.
If I get that bored ever, then I'll make it as an add on to MS, but don't hold your breath, it's not happening any time soon
Richard
Richard
megasquirt has been doing ignition for over a year now ! - the problem is unless someones decodes the signal from the flywheel and writes software for it - you have to mount a trigger on the front pulley - if you havent noticed , there isnt much room down there .
Of course MS can be used as a piggyback aswell
[url]http://www.volvo480sport.co.uk[/url]
- 480 Veteran
What are the two types of flywheel on the B18FT? Are they both missing tooth?
Found this http://megasquirt.sourceforge.net/extra ... wheel.html
Megasquirt seems pretty cheap, look on ebay for buying it. Also, you could build it yourself.
- rpruen
The two types have a slightly diferent patern, they are both missing teeth.
The MSnS code is doing the same thing as the bosch hardware, except that the hardware triggers on the nearest tooth edge to the ignition point, then there is a short delay to get fine control. The MSnS has a longer variable delay after triggering well back from the spark point.
It does the same thing in the end. The bosch system doesn't use the CPU though, only to put the right numbers in the counters. I think they did that as when the system was designed CPUs where not close to as powerfull as now.
Richard
Richard
- Ettore Bugatti
How would a Megasquirtsystem look and costs as a extra fuel injector controller? I think a MS cost as much as this piggyback sytem when you would use it as a e.f.i.c.
Im after a system where the stock ECU controls the standard boost+ some extra and the add-on controller supply the extra fuel for more boost. The problem only is to keep the stock ECU happy when the boost is beyond it range.
- rpruen
Interesting idea. Unfortunatly it isn't that simpleEttore Bugatti wrote:How would a Megasquirtsystem look and costs as a extra fuel injector controller? I think a MS cost as much as this piggyback sytem when you would use it as a e.f.i.c.
To have the ECU happy with the extra boost means modifying it. If you are going to do that then it's just as easy to have the standard ECUs deal with the extra boost and fuel. It's also likley to work out cheaper to do it that way, you still need the bigger injectors etc. but you don't need any add on boxes to make it work.
The standard ECU will be ok up to 28 psi, after that the resolution of the A/D may well become a problem for the fueling side. The ignition may well go up to 50 psi as it'a a 10 bit A/D (it would mean using a 5 bar MAP sensor)
Richard
