I'm considering a manual conversion.
The car has a Robou ecu, so I was wandering if there's any difference in the ecu, or will I have to make any other changes?
auto/manual ecu
- doingitsideways
auto/manual ecu
Hammers can't fix a 480!!!
Re: auto/manual ecu
steve is it a 2ltr NA car if so read off the serial/part number off of the ECU and post up here.
- doingitsideways
Re: auto/manual ecu
Sorry Jim, I'm talking about the 460T.
Turbo and currently auto, looking to convert to manual. Also Roboumodded, don't know what effect that may have.
Hopefully, The Oracle himself will be along to enlighten us with his wisdom
Re: auto/manual ecu
Can't resist. Same ECU is used in both manual and automatic. Ignore the switches under the selector, my mod controls torque in a different way.
Too old to bother
480 Turbo midst '91
480 Turbo midst '91
- doingitsideways
Re: auto/manual ecu
Thanks, R-Oracle-Bou
Although, switches under the selector?
Not stripped the car down yet, but if I find any, I'll ignore them
I only asked in the OP because I seem to remember reading something about one pin going to ground on manuals, providing more torque or something.
Could be talking crap.
Re: auto/manual ecu
Less torque in reverse. Switch under the gear shift. I bet you guessed that.
Too old to bother
480 Turbo midst '91
480 Turbo midst '91
