5w DRL's ?
Posted: Sat Feb 07, 2015 5:45 pm
by oldgitdave
I was lucky enough to be given some cash at Christmas & decided to buy new front light clusters
. They came from The Netherlands & had both the indicator & DRL bulb holders fitted, though the DRL's were the European 5w fittings. Anyway, using the original bulb holders I thought I'd try & keep the new clusters pristine & avoid the dreaded toasting of the plastic lenses by fitting LED's. I've tried everything to fit LED 21w/4w bulbs but they've either not dimmed or have stopped the pop-ups working & the light is so white it doesn't match the headlights or spotlights so would probably fail the MOT here in the UK. So my question is... can I use the European 5w holders & fit 5w bulbs? Is it legal in the UK & will everything still work? We all know how sensitive the 480 electrics can be
I would really like to fit warm white LED 21w/4w but haven't been able to find any anywhere. Any advice greatly appreciated. Thanks,
Cheers,
Dave
Re: 5w DRL's ?
Posted: Sat Feb 07, 2015 8:37 pm
by timrosser
I got some led driving lights off Spree and they are great, they keep the lens cool and the temp builds slowly so there is no super fast led on / off thing.Mine has been through 2 mots with them, although I think your right, technically I should have been picked up on that but they look very natural!
Re: 5w DRL's ?
Posted: Sat Feb 07, 2015 8:44 pm
by oldgitdave
Thanks timrosser, I did pm Spree but got no response I guess it's a while back since he did the LED's. For now I'm running with the LED's that don't dim. Not due for MOT for a while yet
Re: 5w DRL's ?
Posted: Sat Feb 07, 2015 11:41 pm
by glasgowjim
I have been through a number of mots (5) and I have the 5w european drls and there has never been a problem with them. They are a lot better than the uk ones and to be honest your car is 20+ years old how the hell would they know what it should like!
so dont worry about it .
ps they are legal
and yes everything still works
Re: 5w DRL's ?
Posted: Sun Feb 08, 2015 10:29 am
by oldgitdave
That's brilliant Jim, thanks
. I'll give mine a go. I was a bit worried they would switch off or only come on once the pop-ups were active as they only have 2 connections & not 3. Should save the front plastics from burning eh? Wish I'd tried this before buying the LED's
Re: 5w DRL's ?
Posted: Thu Mar 12, 2015 10:18 am
by Martin Mc
My DRL are not only toast, but now broken both sides - I'd like to replace the clusters entirely both sides (one is a late clear version, one an orange). Is there a website for the Netherlands supplier?
Re: 5w DRL's ?
Posted: Thu Mar 12, 2015 5:55 pm
by oldgitdave
Hi Martin,
I had mine from here:
http://www.estateservices.nl .
Looks like I had the last ones as they're not available now
Regards,
Dave
Re: 5w DRL's ?
Posted: Wed Oct 24, 2018 1:26 pm
by nixell
You can get ones from a Volvo dealership through the spare parts shop. I used this method got get a pair of new OEM parts, the later, clear white model for my Turbo. Mind you that was several years ago, so I'm not sure they are still available.
Re: 5w DRL's ?
Posted: Wed Oct 24, 2018 2:04 pm
Ah, those were the days! Unfortunately neither colour indicator cluster is available new anywhere now. If you are patient, you will eventually find a decent pair on eBay as they do come up, often from Europe. You might even get new-old-stock.
