Turbo engine limits
- doingitsideways
Turbo engine limits
So, I'm toying with building a bit of a monster Turbo lump. Well, as much as possible without breaking the bank anyway.
I was wandering if anyone knows the sort of power that the internals can take. Rods, crank, head/studs etc?
Current plan is to port/pollish the head, T25g turbo, bigger injectors - thinking from a B230t, decent exhaust, then go from there.
Any thoughts appreciated
Cheers,
Steve
Cheers,
Steve
Hammers can't fix a 480!!!
- jamesy12345
Re: Turbo engine limits
well Robou's ECUs get them up to 170 /180 on standard internals, Rpruen did lots of work to get to near 300 IIRC...so I think the answer must be somewhere in between the two!!
Not much help I know
Give me a shout if & when u want this T25G
Regards,
The Swap Shop Assistant
Regards,
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
- doingitsideways
Dear Swap-Shop Assistant,
I would indeed be interested in your T25g.
Would you be willing to do a deal, with the obligatary packet of Monster Munch and half eaten Crunchie?
Many thanks,
Steve "home of Jamesy's previous projects" Sideways
Many thanks,
Can supply a set of 4 bigger injectors (or so I was told at the time just never used them)
can I have the monster munch pleeeese
- doingitsideways
A savoury man then, Jim??
Any preference on flavour?
Worth bearing in mind though, that roast beef will require the injectors cleaning!
- jamesy12345
a deal eh? Got to be worth a couple of those Ronals at least
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
- doingitsideways
2 Ronals, 1 a little scuffed.jamesy12345 wrote:a deal eh? Got to be worth a couple of those Ronals at least
No tyres.
There is no answer in between. Richard Pruen invested a lot and blew up everything in the end. Everybody did. Buy or build yourself a car that answers your demands.
Injection is a timed pulse. Bigger injectors let pass more fuel. Your lambda sonde does it's utmost best to correct this until about 3200 rpm. Then the engine runs with too rich a mixture. Fun!
The original turbo speeds up very fast. It is made for (only?) 1 bar maximum. If you mount a "bigger" turbo a lag will occur and the higher boost will not be answered for by the ECU, because the MAP only translates to 1 bar. So the mapping goes haywire. Fun!
The solution is a two years study in electronics and Megasquirt and doing away with the ECUs and MAF, because no one will assist you in rebuilding/adjusting the original ones. Even the super-richmod (or what it is called) died premature.
The oracle has spoken once again. At your service. I admire your fantasy.
Too old to bother
480 Turbo midst '91
480 Turbo midst '91
- doingitsideways
Ha ha ha!
Thanks Robou, the Oracle!
So, have you any advice?
I think I would really be happy with 200-220bhp. That would make a really lively little car.
Tell me straight, am I dreaming to even get anywhere near that without epic problems??
Many thanks,
Steve
Many thanks,
Steve
- jamesy12345
T4 engine?
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
- doingitsideways
Hmm...jamesy12345 wrote:T4 engine?
I'll wait for a project thread!
