B18E 1,7i Catalytic converter removal
NorwegianGTE
Post by NorwegianGTE » Fri Jan 13, 2012 9:36 am
Hi
I wonder if anyone have removed their catalytic converter on a standard 1,7i in order to increase performance and power? Since the B18e/ft has the oxygen/lambda sensor on the exhaust manifold it will still be mounted if you remove the cat. I have installed a non catalytic exhaust system on my R5 GTE (has B18e non turbo from factory) and it seems OK, though I haven't fully tested the car yet but when warm it was idling around 1500 rpm. A bit high I think.
avaconirl
Re: B18FT 1,7i Catalytic converter removal
Post by avaconirl » Fri Jan 13, 2012 1:38 pm
I am running a 1990 std 480es with no innards in the cat box and it run's great with no prob's.( I bought it like this.) My son had a prob with his bmw e36 where the cat got blocked so again removed the inside with a slight increase in power.
V480TI
480 Expert
Re: B18E 1,7i Catalytic converter removal
Post by V480TI » Mon Jan 07, 2013 11:08 am
B18E has no catalytic converter......
Greetz
eye of ra
Post by eye of ra » Sat Jan 26, 2013 10:27 am
There were some B18e with cats, my 1989 ES has one, the owner’s manual describes it as B18e(d)104 and had the word “catalyser” on the rear of the car. The B18e(e)104 did not.
I to was looking at removing it at some point as it was not a requirement to have one in 1989 but as of April 1st it will be an MOT failure.
Quote from the AA on the new MOT rules coming in states
Exhaust
A catalytic convertor fitted as original equipment but missing will be a reason for failure
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
V480TI
480 Expert
Post by V480TI » Wed Jan 30, 2013 5:44 pm
I am still right... the B18E has no cat originally, the b18ED has.... but that doesn't matter.
However will be a mot failure I think.
Greetz
eye of ra
Post by eye of ra » Thu Jan 31, 2013 2:31 pm
And there I was thinking I had worked out the engine codes when I first got my car.
I thought B18E was a general term for B18E(E), B18E(S) and B18E(D).
So am I now correct for injection, non turbo?
B18E......104....80kw....No cat....1986-89
B18E(E)...104....80kW...No cat....1988-89....Same as B18E just different name used in handbook.
B18ES.....105....80kw....No cat....1986-88....Exhaust recirculation system.
B18ED.....104...78kw.....Cat.......1988-89....No Lambda.
B18F......106....70kw.....Cat.......1986-90....With Lambda.
B18EP.....115....78kw....No Cat....1990-95
B18FP.....115....75kw.....Cat.......1990-95....With Lambda
EoR
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
