Having read through thousands of threads on here ive learnt that the ECU will cut fuel above 13psi.
But ive also read people say that when they fit the MBC they only turn it up to the end of the yellow section.
Now my Gauge reads in lbs/in2 which is PSI, and the maximum is 14psi.
What else needs to be upgraded to turn the boost up to about 11 or 12psi? Surely the end of the yellow section is about 8-9psi?
Im not looking for massive gains, just enough to put a smile on my face.
