how long does it take?
with your boost turned up how long does it take for ya to get to 140mph
and in what stages (can you break it down)
i get fast to 80 then slows a bit to 100 (4th gear) and slowly to 140 not rapidly!!!
does the little t2 run out of puff higher up the revs and speeds?
edit by coyote : moved to tuning and tweaking
***CAR FOR SALE 2K AND ITS YOURS***
- coyote1980
- Volvo 480 Club Europe CREW
it wasnt at all a bad idea, so you say the engine is pish its only fast because its ina light tin foil car?
rubbish i have alot of faith in the car, and a little research found out that the t2's run out of puff at and psi above 4k, where as annice new t25/t28 or even a nice t3 would pull alot harder and also have a lower charge temp so will make it safer for the engine.
- Ben Harris
Jamo had a bigger turbo put on his - so physically it's possible. I also know he had bigger injectors fitted (from a Saab 9000?) I'm not sure what else he had to do though.
Ben.
Ben.
why wouldt it?
if anything it would be safer than the t2 is, as a smaller turbo to run high psi means it has to work hard to compress the air and also meaning very hot air, a larger turbo does not have to work as hard and this means the charge temp goes down and power goes up (very rough but trough explination)
meaning internals run cooler.
