how long does it take?
king_j
Post by king_j » Mon Apr 12, 2004 3:21 pm
correct but what makes everyone think the 1.7 is such a gutless engine that it cant produce enough puff to turn the turnbine?
the faster an engine goes the more it produces, thats why a hybrid would be best a t25/28 compressor with a t2 turbin meaning it would spool up like a t2 but produce the power and lower temps of a t25/28
***CAR FOR SALE 2K AND ITS YOURS***
MatBat
Post by MatBat » Mon Apr 12, 2004 3:24 pm
Getting into Twin Turbo territory here. ;) People have claimed to be able to produce 220hp from the Standard turbo, so what's the point in trying to bolt on a bigger turbo?
1996 Mini Classic 1275.
martinholmesuk
Post by martinholmesuk » Mon Apr 12, 2004 3:27 pm
Why bother with our engine if you need to mod the thing? Could you not install a bigger engine or a v6 ? :dunno:
Audi TT
volvofox
Post by volvofox » Mon Apr 12, 2004 3:28 pm
its all about physics
a brick is harder to kick away far than a football :rofl:
a 1.7 turbo is not gutless, you know that, else you would not have fitted it in.
try a chip
luck,
JPF
Nomen est Omen
king_j
Post by king_j » Mon Apr 12, 2004 3:42 pm
i mean there are so many factors to why i aint getting the same top end (heavier car, my bonnet being fucked and now shutting right and causing lift and alot of drag, the fact i think im running very fuel rich) all these things need checked also a nice rr session will find anythign else.
i have alot of faith in this engine and me and another PMT m8 are looking to mew manifolds, throttle plates, turbos (and converter plates) and other nice moddifications to change this engine into what volvo never intended.
dbsvolvos
480 Expert
Post by dbsvolvos » Mon Apr 12, 2004 3:46 pm
well your motor will always be slower at top speed , since frontal area will be bigger , and i dont care what you say about CD figures they are a dimensionless ratio , frontal area plays a big part youll find the 480 a lot smaller than the laguna , jamo has a T25 compressor housing which is easily good enough for 250 hp , even if the exhaust housing will become restrictive and EBR will become excessive .
[url]http://www.volvo480sport.co.uk[/url]
king_j
Post by king_j » Mon Apr 12, 2004 3:53 pm
uhuh
king_j
Post by king_j » Mon Apr 12, 2004 7:31 pm
hehehe this is/was gettign worse, hardly any power i needed but the boost guage was going up to the red zone.
so took here home did a compression test (12 bar+ all round)
and checked the plug all seemed good, little black but nothing excessive.
and then noticed that there was a small cut/knick in the hose that goes from the boost hose between the inlet manifold and the intercooler and the idle control valve, i took the hose off and blew in it and was able to make it hiss with very little effort so im guessing that when the hose is pressurised it would have no problem loosing some prassure through that. so i repaired it and rebuilt the engine back up making sure everything was nice and tight. started her up and she idled smoother, ive not been back out in it yet but ill let you know if this has cured the problem ive been having.
robkendall
Location: 2nd star on the left and straight on til morning
Post by robkendall » Tue Apr 13, 2004 5:27 pm
personally, i would rip off the turbo,and stick on a blower (supercharger)
did this with an s40, didnt change the max hp much (couple of hp better), but performace wise was redhot,instant power, as it doesnt rely on the exhaust to get the turbine up to speed.
If you think about one, get one with twin trefoil, or cinqfoil rotors inside....cant remember name of website,but its something like volvo automotive parts?
the kits complete with everything you need to convert turbo to super.
Could the N/A 480 be changed to put on a turbo?
mines a 480s 17i N/A engine.....what would be required to turbo it?
would it b a case of 'bolting one on?'
rob
MatBat
Post by MatBat » Tue Apr 13, 2004 5:56 pm
I too agree that supercharging is a far better means of Forced induction.
king_j
Post by king_j » Tue Apr 13, 2004 6:20 pm
ive fixed it people and can i just say fucking WOW.
dbsvolvos
480 Expert
Post by dbsvolvos » Tue Apr 13, 2004 6:27 pm
well , im glad it works ,
i wont get into the which is more efficient turbo/supercharge etc .
you could quite easily supercharge a turbo one since all the plumbing and ecu could handle 10 psi , if you have na then youll have to muck about with the fuelling and timing , since it wont be correct for the engine .
john hotchkiss
Post by john hotchkiss » Tue Apr 13, 2004 6:28 pm
what would supercharging give a turbo
it drains my pocket but i cant help doing it..
black 480 turbo
dbsvolvos
480 Expert
Post by dbsvolvos » Tue Apr 13, 2004 6:33 pm
you wont make any extra power , it will just drive different , with no lag , but a T2 is hard to beat on spool . My reasoning was that the ecu can cope eith the extra demands of the engine so using a turbo ecu , would make life a lot easier , but why not just buy a turbo .
And if you havent been in a turbo with a boost controller , the you are missing out .
john hotchkiss
Post by john hotchkiss » Tue Apr 13, 2004 6:36 pm
i have a turbo 1990 with a boost gage as standard on the dash what would a controller give me.. :o
black 480 turbo
martinholmesuk
Post by martinholmesuk » Tue Apr 13, 2004 7:03 pm
I like my MBC :twisted: Best money I ever spent :hopping:
Audi TT
king_j
Post by king_j » Tue Apr 13, 2004 7:08 pm
i guess a supercharged lump needs the same setup as a turbo (low comp pistons etc)
so i guess the ecu doesnt care whats blowing the pressure as long as its getting what i needs?
so you could have both?
if it was all set up to handle it
JohnTurbo
Post by JohnTurbo » Tue Apr 13, 2004 7:40 pm
Not sure about an MBC, i'm more keen now i've reallised the engine doesn't have wet liners........why doesn't it? I thought it would have being renault! Does the efficiency go through the floor? - plus if i floor 4th i get to the end of the yellow as it is.
As for the transplant i'd imagine one of the factors for king_b was that you can pick up a 480TURBO for hardly any money.
Mine was GIVEN to me, and i've never seen one in better nick.
- did need alround discs and pads tho (and 2 pipes)
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
volvofox
Post by volvofox » Tue Apr 13, 2004 9:40 pm
:lol: what did you have to do to the guy who gave you this great car :lol:
one still have to pay thousands of euro's for a good 480 in most other countries
luck,
JPF
Nomen est Omen
johnd
480 Expert
Post by johnd » Wed Apr 14, 2004 4:28 pm
John a boost controller would give you a kick in the ass and a look on your face like...... :D
.....for a good half hour afterwards aswell!!
John
Citroen 2CV, lowered on 12" Wooden wheels, performance 1cm exhaust, stabilisers & chemical toilet in drivers seat
94 480 Turbo - now the missus's car!
Judas's car!! - 292BHP Celica GT4....I couldn't help myself!!
