Hey Dudes,
How have you solved you oil temp issues? Just a sandwich plate and an cooler, or is there a better setup with thermostat?
Oil Cooling
Oil Cooling
Volvo 480 1990, Vovo 855 t5
Re: Oil Cooling
Mount a water cooler matrix in the front and have the water supply for the oil cooler run through. Makes a difference of 5 degrees under heavy load and has the advantage of being effective when the fan hits in.
Too old to bother
480 Turbo midst '91
480 Turbo midst '91
