Don't understand wheel numbers
Right I've been trying to work out if some aloys will fit on my entirely standard 480. I've red a few old posts and was a tad confused by ofsets and the like.<br><br>So here's the wheels I'm thinkning of getting... Volvo 17" Comet wheels with Pirelli Pzero 205/45ZR17 tyres. They have an offset of ET43 (and at the end it says PCD 5x108 but I'm not sure if that's to do with the wheels or something unrelated).<br><br>So if anyone could kindly advise me as to whether they'll fit on my 480 that'd be great. I don't want rubbing or damage or anything! <p></p><i></i>
- Jamo
Re: Don't understand wheel numbers
O.K first off mate, forget those alloys they wont fit full stop.<br><br>Let me break it down for you (Hammer Time)<br><br>Lets take your alloys you were thinking off as an example:-<br><br>PCD 5x108 : - <br><br>This is the defining factor for fitting alloys, every car has it's own individual PCD (although most share a common standard one)<br>PCD stands for Pitch Circle Diameter.<br><br>In this example the alloys have 5 stud holes (5x), so that they make a diameter of a circle to 108mm if you drew a circle through all 5 points <br>i.e the circle diameter would be 108mm<br><br>The Volvo has a PCD of 4x100 i.e 4 stud holes that make a circle of 100mm diameter<br><br>As you can see the alloys you were looking at wont fit!, to many studs and the wrong size.<br><br>(Another thing to bare in mind and this is important as alot of younger car modders dont pay attention to it is the centre bore size. <br><br>This is the size of hole in the middle of the wheel and this needs to match the car or else an adapter (sprigot ring) needs to be used to get the correct centre bore.<br><br>The volvo 480 has a centre bore of 52.)<br><br><br>offset of ET43:- This is the amount a wheel leans from the centre point and can be positive or negative. It's a bit like camber.<br><br>Easier to see than explain: erm let me borrow a link<br><br><!--EZCODE IMAGE START--><img src="http://www.tyres-online.co.uk/images/aug99/offsets.gif" style="border:0;"/><!--EZCODE IMAGE END--><br><br>To cut a long story short the ET for volvo 480 is in the range 32-38.<br><br>Typically you want an ET37 or ET35 in that order.<br><br><br>Pirelli Pzero 205/45ZR17 tyres. :-<br><br>Good choice in tyre!!!, thats what i have on mine.<br><br>205 is the width of the tyre, 45 is the size of the sidewall (bit visible when looking side on at the wheel) and R17 is the size of the tyre in inches.<br><br>If you were going for 17" wheels on a 480 then you would want 205/40/17 as this would keep your speedo correct to a couple of mph! (changing the size of your wheels effects the accuracy of the speedo if not done correctly).<br><br>You might get a bit of inside scrubage, but nothing really major.<br> <p></p><i>Edited by: <A HREF=http://pub32.ezboard.com/bvolvo480.show ... oDodger</A> <IMG SRC="http://www.photobucket.com/albums/0603/ ... 8d5b65.jpg" BORDER=0> at: 8/29/03 8:09 pm<br></i>
Think jamo covered this a lot better than me and posted at the same time, so yeah... Just ignore this one!!!<br><br>pol <p></p><i>Edited by: <A HREF=http://pub32.ezboard.com/bvolvo480.show ... >polTN6</A> <IMG SRC="http://members.aol.com/urquhartps/stuff/turbo1.jpg" BORDER=0> at: 8/29/03 6:15 pm<br></i>
- Jamo
LOL sorry Pol, i just learnt a bit when looking around for mine. <p></p><i></i>
- dragon
- Volvo 480 Club Europe CREW
Oddly, changing to 17" wheels had no discernable effect on the speedo accuracy in my case, all I can say is "good choice of wheel, Hans!" <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> <p><!--EZCODE BR START--><br /><!--EZCODE BR END--><!--EZCODE BR START--><br /><!--EZCODE BR END--><!--EZCODE ITALIC START--><em>1995 480 Turbo, Flame Red Metallic, Jacquard/Leather</em><!--EZCODE ITALIC END--></p><i></i>
Thank u
Right just got your replies now... thanks, especially for the very indepth wheel lesson. Much appriciated. To be honest I did also have in the back of my mind that 17" might be a little too huge looking anyway. Some Cetus wheels would be great though... I think they make the 480 look fabulous.<br><br>Thanks again<br>James Carruthers <p></p><i></i>
earlier 480 wheels
Only some extra information<br>The aerlier 480ES had also alloywheels<br>with <br>6x14 E40<br>Good CEM<br>Gerrsvolvo <p></p><i></i>
- dragon
Re: earlier 480 wheels
Actually, I find Jamo's explanation so sueful, I think it ought to be included on the clubsite in the FAQ section. Also, I'd like to put it on my site - any objs, Jamo? <p><!--EZCODE BR START--><br /><!--EZCODE BR END--><!--EZCODE BR START--><br /><!--EZCODE BR END--><!--EZCODE ITALIC START--><em>1995 480 Turbo, Flame Red Metallic, Jacquard/Leather</em><!--EZCODE ITALIC END--></p><i></i>
- Jamo
None Dragonlord.<br><br>Gerrsvolvo - You are correct, except those wheels weren't released in the U.K<br><br>The Pollux and Atlas rims where ET37, Taurus ET33<br>I dont know what the Cetus were but i think they might be ET33 as well?<br><br> <p></p><i></i>
