DevilsOwn Water/Methanol
volvo-tom
Post by volvo-tom » Sat Jan 15, 2011 10:35 pm
Today me and my mate daz installed a devilsown kit on my turbo,
( http://cgi.ebay.co.uk/DEVILS-WATER-INJE ... 127wt_1139 ) considering were both just 16yrs old it was surprisingly easy to fit, it took me and my mate about 6hours to fit and test it. The i cant really tell any difference atm but then again all ive had to test it on is a long'ish' drive way lol
(to save the hassle of having to tap into an ignition source i simply placed a toggle switch in the engine bay)
the only problem i had with the kit was locating a vacuum/pressure line, the only way i cud do this was to just randomly pull off pipes in the inlet and see which ones caused the pressure switch to activate when on boost, i used an LED light strip on the bonnet to show me when it was active-
i later found one on the throttle body housing that did just the job
if anyone has any questions feel free to ask!
thanks for looking,
tom
volviz
Re: DevilsOwn Water/Methanol
Post by volviz » Mon Jan 24, 2011 8:58 am
at what pressure you sat it to activate?
I don't think that you will see any difference while the car is fairly stockish, but certanly will help if further modifications are planned... ;)
Image&ImageImage
Auk
Post by Auk » Mon Jan 24, 2011 10:57 pm
Hmm, don't want to bother you but your engine is breathing hot air instead of cold air... not really a upgrade, that airfilter..
Auke
Volvo. for life
volvo-tom
Post by volvo-tom » Tue Jan 25, 2011 5:25 pm
ive got it set to 6psi at the moment, its got a boost controller so the main reason was too reduce the chance of dettonation, it'll also hopefully cool down the intake temps.
I did think about the air filter, but altho u cant see it in the photos it does hav a cold air feed goin to it, and plus i figured surely the intercooler would cool down the air going into the engine anyway :-)
,tom
volviz
Post by volviz » Mon Jan 31, 2011 5:57 am
one more quick question... I can't quoite understand where the spraying nolse is located, behind air filter?
Image&ImageImage
volvo-tom
Post by volvo-tom » Mon Jan 31, 2011 4:22 pm
no problem, its located at the front of the inlet manifold, just before the throttle body (after the air filter), i hope this pic helps -
volviz
Post by volviz » Tue Feb 01, 2011 7:09 am
nice thanks ;)
Image&ImageImage
martinholmesuk
Post by martinholmesuk » Wed Aug 03, 2011 7:42 am
Hi,
I have the same kit on my supercharged mx5. The intake temps have gone right down. In fact the inlet pipe is ice cold. I am using a mix of water and isopropyl (99.7 alcohol)
is your pump higher then the water bottle? I pretty certain the pump should be below.
I run my 5lt tank from the boot.
