can i uses these injectors
clio 480 turbo
may have found out that my injectors have packed up, but i bought a set of volvo 740 2.3 turbo ones of this forum a couple of years ago from (johnturbo) 315cc flow rate could i uses these instead my car has rich mod uprated t2 turbo fmic, mbc etc or will these be to much for the car
Re: can i uses these injectors
Renault 5 GTT *volvo 480 turbo power*
161 BHP & 230 Nm @ 10 Psi -->Now running on 18 Psi :P
soon --> new engine in with 315cc injectors t25/28 turbo an BIGMOD :)
clio 480 turbo
dont undertand, this is the part number on them 0280150804
- volviz
These are low resistance, so will not fit directly.
But resitance box can be puted in circuit to make them work
But also I see that you have rich mod, so you shoud contact johnturbo, cause.... Richard used to adapt factory ecus for low resistance injectors too....(just check the injectors that you have in car..and use with the similar resistance).
clio 480 turbo
injectors in the car are stock
hi i use volvo 740 2.3 injectors atm they are 227 cc
0280150749
0280150749
- volviz
so you can't use 0280150804clio 480 turbo wrote:injectors in the car are stock
