[480T] MAF to MAP conversion-is it possible?
- bigdickbuster
Well as the title says. Anyone have experience with this?
ex 1990 480 TURBO, model year '90, 231 Red
This car was a mistake
This car was a mistake -
ted clutch
Re: [480T] MAF to MAP conversion-is it possible?
not easy with the standard ecu. the difference being a maf measures the actual airflow with a heated element while a map measures the manifold pressure and then the ecu has to use a lookup table of revs against manifold pressure to get the airflow. this is because the volumetric efficiency changes (gets lower) as the revs go up. in plain english the higher the revs the harder it is for 8 valves to breath even if the manifold pressure is the same. you would need to significantly rewrite the software, maybe even add hardware for the lookup table.
the actual sensors arent interchangeable in any way unless you used some sort of piggyback ecu with rpm input,map input, lookup table to produce maf compatible signal for the standard maf input.
- bbf
Why would you do that? FT has allready a MAP senzor in the turbo ecu, btw..
'86 480 ES, RIP :(
'91 480 Turbo, RIP :(
'93 480 2.0, RIP :(
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
Hi
Have a look at perfect power's range of piggy back ecu's they provide the map tables you need for this & they're reasonably priced.
LIP
LIP
- bigdickbuster
Thank you for digging my topic. Unfortunately my Turbo lost the gearbox, and conversion must wait
