Wiring of a 480 turbo engine in a Renault
Hello all
I know I've asked for help several times but it is now that I'm actually fitting the engine in my little 5. I had some health problems and was stuck in hospital for over 2 months pretty damn sad 2 months..
Anywayssss.. here it goes.
The bulkhead on my engine loom has 10 wires and not 5 like some of you have told me. These are the colours as follow;
thick grey/red
grey/red
grey
brown/blue
pink
green
red
blue
brown
white/blue
As mentioned above, the only relatively thick wire from the whole lot is in grey/red. Now alot of users on this forum told me that I just need to use a grey (ECU live), a grey/red (fuel pump) and a brown/blue (tacho) wire to work with.
The grey one is fine; ECU ignition live.
I've connected that to the ignition and turned the ignition on. Now a grey/red wire should read 12v with a voltmeter, right ? Well the only wire to give me a 12v supply was the pink one so i think that's the fuel pump one.
Now another problem I've got is that the pump is not stopping after a while when turning on the ignition. At first you can hear it working hard and then after a while (when it should completely stop) you can hear it run lower, as if its trying to squeeze fuel in.
There are no leaks what so ever.
I just tried to start the engine once, last night, and am submitting this from work. What I was thinking about maybe the fuel rail and all the stuff must first will up first time start up..
But as with every fuel pump it must have a pressure switch to turn it off after priming, right ? or is that done by the master relay ?
Any help would be greathly appreciated. Thanks
thick grey/red
grey/red
grey
brown/blue
pink
green
red
blue
brown
white/blue
- bbf
turbo doens't have prime presure switch or anythink like that. it needs 3 or so cranks of starter motor (or one at jumpstart by pushing-draging) to start pumping and stops right after no signal from flyweel senzor. you can put it directly to switched 12V and it should be fine. (but if you crash and cut fuel line it will pour benz until you switch it off..)
I propose you download the wiring diagrams and start there, not with wires in your hand.
engine transplant will also need some knowledge of what you are doing and a lot of modifications to r5 to make it safe to drive.
'86 480 ES, RIP :(
'91 480 Turbo, RIP :(
'93 480 2.0, RIP :(
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
Ohhh thats a completely different story .. thanks alot for that piece of information.bbf wrote:turbo doens't have prime presure switch or anythink like that. it needs 3 or so cranks of starter motor (or one at jumpstart by pushing-draging) to start pumping and stops right after no signal from flyweel senzor. you can put it directly to switched 12V and it should be fine. (but if you crash and cut fuel line it will pour benz until you switch it off..)
So you reckon that only when the flywheel sensor senses some rotation only then will the fuel pump work, right ?
Then that takes me back to choose me coloured wires..
Fuel pump problem solved
But engine stil does not start .. Ignition looks veryyyy weak. Tomorrow will be checking out this mishappening as now I have to rush to work.
I've also got a plug which is still not connected.. its a small cylindrical shaped plug, 2 wires, red&black, just before the airflow sensor plug and just after the throttle positioning plug. Any ideas ??
how did you solve the fuel pump as im wiring the same loom to my clio and the plug i think your on about is the aux water pumpr5b18ft wrote:Fuel pump problem solved
fuel pump was ok .. amazingly enough all 4 injectors where stuck, not a even a single drop got through one of them. The engine had been sitting down for over a year an a half so I could have presumed that. Well now they're fine and engine is runningblaze wrote:how did you solve the fuel pump as im wiring the same loom to my clio and the plug i think your on about is the aux water pumpr5b18ft wrote:Fuel pump problem solved
