Has it been done
reevio
Has it been done
Post by reevio » Wed Aug 26, 2009 7:31 pm
volvo 480t bottom end matted with a clio 16v head turbo charged
volvo v40 t4 2001 daily 210bhp
volvo 480 turbo lump in my clio valver bhp?
Chesh
Post by Chesh » Tue Oct 27, 2009 1:04 am
I know the engine in question in this example is from a volvo but if its the same f7r as in the willy/meg then here is your answer mate ;)
volvo-forums
com/t23252-440-20-turbo-conversionhybrid.htm
No reevio, you cant escape lol
gixfighter
Post by gixfighter » Thu Nov 12, 2009 11:58 am
You will be able to make it fit, only small constructual problem is the cooling channel on one side. A big problem as follows:
The standard volvo head is a flat head, means no combustion chamber in the head but in the pistons.
The renault 16v head has the combustion chamber in the head, and flat top pistons are used in this engine.
So if you use the 16v head on the volvo bottom end, you'll have two combustion chambers, reducing the compression ratio as far as below 6. That will give you no low rpm torque.
Better you buy a thicker head gasket for you 16v engine, reducing the compression ratio to about 8-8.5. and put the turbo on this engine.
Renault 19 Convertible with 480Turbo Engine Megasquirted and soon being supercharged
Renault 5 GTE with 480Turbo engine: Rusted
ted clutch
Post by ted clutch » Thu Nov 12, 2009 11:58 pm
could he skim the hell out of the 16v head to bring the comp back up?
reevio
Post by reevio » Sat Dec 19, 2009 7:13 pm
cheers for the reply lads and yes chesh i acnt escape from you lol i still really want to do this
