modded MAF??
gvanminnen
modded MAF??
Post by gvanminnen » Sat Aug 01, 2009 7:50 pm
I read some things about modded MAF's but not how this works?
Somebody who can tell me how I can tune my MAF and what is the differents?
Bigger turbo and stuff. Home tuning:D
Ettore Bugatti
Post by Ettore Bugatti » Sat Aug 01, 2009 10:31 pm
Look for post of rpruen and/or tobi480turbo. They had a nice topic called tuning ecu's or something similiar a few years a go (2005?)
The end result was 240hp (from a B20F, though)
Rover Mini 1000, june 2009-
gvanminnen
Post by gvanminnen » Sun Aug 02, 2009 9:30 am
I have looked for it but no results. I will search again. THX.
gvanminnen
Post by gvanminnen » Sun Aug 02, 2009 9:57 am
I can't find it, but saw something about a saab MAF but no explanation.
Rpruen can mod it for bigger injectors but stopped with tuning.
So can nobody tune a b18ft engine or knows how it is done?
gvanminnen
Post by gvanminnen » Sun Aug 02, 2009 12:30 pm
There is also a bolt (adjusting srew) in the MAF, what can you adjust with that?
Post by glasgowjim » Sun Aug 02, 2009 12:50 pm
do not understand what you mean "blod" ??
Is this a variable resistor you are talking about?
Sieger
Post by Sieger » Sun Aug 02, 2009 4:17 pm
try to make a bypass pipe that excludes the MAF, pipe needs to be 20 mm till 30 mm to get the best AFR
this was done by a guy that also tunes B18ft ecu's
The best result this guy had was just simpley make a hole in de pipe after the MAF.
Renault 5 GTT *volvo 480 turbo power*
161 BHP & 230 Nm @ 10 Psi -->Now running on 18 Psi :P
soon --> new engine in with 315cc injectors t25/28 turbo an BIGMOD :)
gvanminnen
Post by gvanminnen » Sun Aug 02, 2009 8:31 pm
Oke but is that also helping with full throttle.
Post by pol » Mon Aug 03, 2009 9:51 am
I believe they increased the volume of the maf by altering the diameter of the casing.
There was a specific volume they were aiming for to match some uprated injectors. I think they sourced some tubing of suitable diameter then took the internals of the MAF and inserted into the new tubing.
How to calculate the volume required I do not know but this is what they were doing.
Try this old link for some info:
http://volvo480.dragons.org.uk/forum/vi ... php?t=4393
Hope that helps,
gvanminnen
Post by gvanminnen » Mon Aug 03, 2009 3:50 pm
Thanks mate :D
MAF need more volume so I have to take the internals of the MAF and make it in a bigger pipe.
gvanminnen
Post by gvanminnen » Mon Aug 03, 2009 8:02 pm
Sow that is not easy to open the MAF. You have to cut the wires to get the top open. Then there are bolts under it.
I will try it when I have a second MAF.
440tic
Post by 440tic » Tue Aug 04, 2009 3:42 pm
i'll have 320cc/min injectors and maf changet 75mm tube, works jus't fine, also T25, richmod, eletrical boost control also etc little things. dunno hp, but more than orig :wink: 460tic
dave r5
Post by dave r5 » Tue Aug 04, 2009 4:06 pm
i dun the 20mm -30mm hole trick and it worked.
for a bit.
then i nuked my engine!
ring me for parts 07805391168
reevio
Post by reevio » Wed Dec 23, 2009 3:07 pm
to much boost dave?
volvo v40 t4 2001 daily 210bhp
volvo 480 turbo lump in my clio valver bhp?
