dump valves
dump valves
hi, just a quick question about dumpvalves ,why do some recirc dump valve kits have adjustable springs for different pressure and what is the benefit?
get a VAG engine recirv valve. I'm running on that no problems. Its made from metall not platric costs pennies and is made to operate @ 1bar pressures.
Ps. I did kill my stock plastic by-pass with richmod out of controll (vacumehose to the boost controller broke)
1996 850R 2.0 T5 - "Beebi R"
1973 142 GL B20E - sold
im using a forge motorsport recirc valve ,but came with 6 springs each of different strengths and am using weakest of springs ,feels about same pressure as original, if vacuum wasnt opening valve what boost reading would i get?
Mine had really bad turbo lag between shifts and felt sloppy under steady accelleration (felt pretty strong under full throttle). I popped one of these in there:
and it's like a new car! Steady boost under all levels of throttle, a huge reduction in lag between shifts and it feels much stronger. I expect to see better fuel milage as well since the A/F mixture will be consistant.
1986 Porsche 951
1991 Volvo 480
1995 Volvo 850 GLE Wagon
2002 VW Passat (SOLD)
1991 Volvo 480
- JohnTurbo
The valve is actuated by a vaccum pipe from the manifold side of the throttle body. When the throttle is shut, a vaccum is made by the engines natural sucking motion.
So the valve without any spring would be on the point of opening precisely when the pressure was equal both sides of the throttle.
Its preferable to have it higher up the accelerator range than this....all you do by canging the spring is alter where that point is, to prevent the valve opening earlier or later than you'd like it too.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
If the valve doesn't open boost will still be created but the excess won't be discharged when you come off the throttle. If you have the black plastic valve, it probably isn't funtioning properly. I've had that part on 3 cars now (My porsche, vw and now the 480) and all three of them leaked boost. To test it, take it out and blow into the side (boost port) no air should pass through the bottom port or the vacuum port. You can also check it by pushing the diaphram open from the bottom, while you're holding it open, cover the vacuum port with your finger. Release the diaphram and it should not close until you take your finger off the vacuum port.
1986 Porsche 951
1991 Volvo 480
1991 Volvo 480
will there be danger of damaging engine in long run if left ?the dumpvalve thats fitted is a forge and i think is perfectly fine,a bit wary of the spring ive used is a bit stronger than standard,i was just wondering whether it is not opening as early as the standard plastic valve because of the higher pressure of the spring.
I seem to remeber been told by rich that these forge valves are to be avoided at all cost.
When the stock valves give up they die in the open position and just allow boost to leak, therfore not killing the engine. on the other hand the forge ones die in the closed postion, not allowing the boost pressure to be dumped, this the kills the engine and the turbo.
From what i can gather the best dump valve to use is a 1.8 VAG one (i.e the ones in passat and a4 1.8 turbos)
I wasnt able to get one of these and use a bosch recirc valve from a saab 95 areo and it seems to work well.
Hope this is of help, and if im wrong im sure i will be corrected!
Toys:-
I belive that forge failing would cause overboost. The main diffrences i think there are between the forge and the VAG valves are the way in which the diagphrams work, wouldnt realy know to be honest though, ive never botherd to look.
Toys:-
- Ben Harris
I replaced mine with an Bosch dump/diverter valve from an Audi TT. Supposedly, it can handle 225BHP, which is much more than my 480 was making, even after a RichMod.
I bought it from here:
http://www.thettshop.com/search.asp?pro ... &site=main
If you so a search on the forum here for 710N (the end of the part number) you'll see that it gets quite a few recomendations.
Ben.
Ben.
