Super Rich Mod
Posted: Tue Oct 07, 2008 2:20 pm
Hi all, does the super rich mod increase RPM limiter???
The place where Volvo 480 fans come together
https://www.volvo-480-europe.org/forum/
https://www.volvo-480-europe.org/forum/viewtopic.php?f=3&t=17006
i think the turbo too big for the engine, or the A/R is inapropriate, maybe a hibryd turbo with correct turbine/compressor wheel match is your answer.AKC wrote:Hi thanks guys for yours replays, I have a friend that has a Renault 5 with volvo engine th same as me but with a bigger turbo and injectors, but the turbo spools only after 4800 rpm, so he has a big problem bacause RPM limiter is set about 6400 rpm or less so he only has about 1500 rpm of power Lol... his car is now about 240hp but he only have 1500rpm of power, I think the Better solution it´s gonna be a Megasquirt if Rich can´t rise up the rpm limiter.
Agreed, the turbo is completly wrong for the engine.yknot wrote: i think the turbo too big for the engine, or the A/R is inapropriate, maybe a hibryd turbo with correct turbine/compressor wheel match is your answer.
It wasn't just the supercharging, it was the whole ceramic coating the entire combustion chamber, and the rest of it.MrE wrote: You just can't help yourself Rich.... If us fitting a supercharger to your own car took a year and half, now your trying to trick someone else into the madness. Still was insane.....for a while!
