injecorts, 3 bar map sensor and super rich mod.
hi there people. iv got a 480 turbo lump in my renault 19 and i want to get more power.its allready got a 1 off cam from QEP if any 1 is looking and also a lightened and ballanced bottom end.im looking for a 3 bar map sensor but cant find any supplyers.does anyone know of one?also are the us spec 740 turbo injectors the same as the uk ones?and does anyone have details of how to do the super richmod? any help is much apreciated.
Tom
Tom
if in doubt, get a bigger hammer
Alright dude,
You gots to send your ECU away to be tinkered with...
Check out this thread http://volvo480.dragons.org.uk/forum/vi ... hp?t=16209
Dont know if they are still doing them now, but its a chap called Rich who does them.
Mines got a richmod and goes like someone stuck a rocket up my bottom.
Regards, Chris
Regards, Chris
hmmmmm
yeh iv read about this rich guy.sounds like he knows a thing or 2.does any one know whqat he actually does to the ecu?as in what he changes?and how? also i still cant find a map sensor or injectors
cheers
cheers
Rich is the gut to talk to regarding the super mod, the one i can get done for you is the "standard" mod. rich remaps the ecu with a new map he has developed over many days of dyno testing!
I will talk to rich when i see him next and find out what is needed for the super mod and see what i can do (if i can do anything, as i belive he needs the "actual" car there to map to it's own caractoristics and not a general map)!
Toys:-
super rich mod
well the car runs in "standard" tune but i want to get the best from the ecu as as standard its cack.if he needs the car i can take it to him once its MOT'd wich shouldnt be too long now.still cant find a 3 bar map sensor.are they from other volvos or is it an aftermarket part?
okie. got my map sensor and injectors ordered. has any body tryed this mod where you remove the 206 and 207 ohm resistors from the ecu and wire a potentiometer in and wind up the resistance to increase boost?is this the same as the rich mod?if not will it work with the rich mod?sounds pretty good.its possable to have a switch between the different resistors so you can run standard or increased boost.
