silly fuelinjection engine
rite, if i try and explain the lay out of my car can sum 1 tell me wat ive dun wron.
to start with,
its a b18ft on an L reg.
in a renault 5 gt turbo
the ecu's are original
vacume pipe wise, the 2 that used to go to the evap system are bloked of, and the 3rd im using as a port for a boost guage.
on the throtle body: 1 before buterfly is bloked off, an the other goes to the blak ecu. an another goes to the blak thing on the idle control valve
on the boost solenoid. 1 goes to compressor housing another goes to actuator. an the litle 1 that i asume is a bleed goes to atmosphere.
i have all my leads the rite way ( this time lol)
and have had the timing cheked.
at a glance and on a multi meter the water temp sensor that feeds the ecu is within tolerence.
the lambda sensor gets warm wen ignition is switched on, an the signal wire is connected
it starts an idles fine and performs well wen warm ish. BUT wen its get hotter say 50 degreesc celcius, it will not let me boost.
i dnt know wat boost its running, as my boost guage is fooked an reeds neg 10 wen car is off, dnt think ive seen it go past 5 psi
all boost circuit is good no leasks!
an im using a sytec fuel pump wich will comfortably hold 139 psi
presure in fuell rail is 55psi
i hope thats anougth info for some 1 to give me a bit of info wat to change check ect
to start with,
ring me for parts 07805391168
that supposed "atmosphere" pipe from the bost solenoid doesnt sound right to me, should go to something. ecu is detecting this fault and stopping the turbo from boosting.
will have a look on my 440t engine as soon as it has stoped raining and see where it should go for you
Toys:-
this boost solenoid must b the bit ive messed up
as it stands all my vac pipes r blue so colours dnt help im afraid
the solenoid has 3 ports
1 to turbo compressor
1 to actuator
an 1 thats ment to go bak to the original intake pipes.
i must have thease mixed up,
does any 1 have a pik so i cud look at wat yr all trying to explain
1 to actuator
First off have you got the solenoid the correct way up?
This picture is how it should be looking from above.
Forget the MBC and notes
Next connect as below.
Last edited by martinholmesuk on Tue Aug 05, 2008 5:41 pm, edited 1 time in total.
yup thats the same way up as i have it.
the top port is the 1 i have nout going to
the botom 2 r the 1s i have going to snail an actuator.
dnt quite understand yr second pictur tho
super star. it now wrks
now its just slow but revs all the way round lol
i like unlimited boost
but i bet the engine dusnt
havnt cheked that yet but wil do tanite. I took it out for a large dose of abuse last nite and was wel happy.
But tnday on way to wrk down motorway it didnt want to go past 4k.
Started poping an holding bak agen
i think ive sused it.
i replaced the temp sencor that feeds the ecu.
an now she seems happy yay
now for the ecu to b sorted my t25 an crank up the boost.
im gona aim for 200 bhp
my 5 only weighs 580kg so power to weight shud b intresting
- Tony Wilson
cheers bud it looks better in the piks lol
the in side is a tad diferent to
anover quik question guys,
its only running 6 psi so isnt all that great at the moment. wat shud it be running?
and were do i put a mbc in between the snail and actuator??
an how much can i turn it up on standard injectord an ecu.
oh an how much if ne 1 knows is omex 600?
6 psi is standard boost on these engines, search the forum for mbc and it will tell you maximum boost the ecu can cope with, but be carful not to over bost it, or the ecu will cut in it's saftey overides (and you will be bunny hopping down the road) and could cause damage
Toys:-
[/url]
