anyone ever fitted one of these?
- clio turbo
less is more!!!
- clio turbo
- clio turbo
for an idea have a look at www.turbobricks.com ,lots of those have squirting for years and really mad guys getting 350bhp froma volvo 740 2.3 turbo OUCH!!!!!
cheers
cheers
MS is ok for a basic rough setup. for a proper setup use something better. I prefered choice would be emerald.
MS is ok and can be quite well setup. But by the time you have gone through the whole setting up with the cost of petrol plus your time and possibly time of others , rolling road etc you are dam near the cost of the emerald which i have seen experienced. All the tuning is done at emerald workshop by the guy who designed the ecu. he is the man. Infact he is know in the trade as mr ecu. He writes for magazines and even for haynes. So he knows his stuff.
hmmmmmmmmmmmmmmm
Mine just started up on megasquirt running spark and fuel, but it was pretty rough. I think I found I had it set up for wasted spark configuration, so it was only firing on 2 cylinders. Had to go back to standard ECUs as I need the car pretty much everyday. Might give it another go tomorrow.
- clio turbo
