racing cams
- eEm
Bosh! Not to scale obviously, took a while to triple check everything but its pretty accurate.
Updated after quadrupal checking lol
Why won't God heal amputees?
- Ettore Bugatti
Thanks!
But can you confirm that the ?=39,6mm
Dont want to push my luck, but do you have the B20F as well?
Guess its time too turn Solidworks or Invetor on...
BTW you can reconize the cams by dots that are printed (stamped) on the cam between the lobes.
There are two rings next to each other. The first ring can have five dots 1,2,3,4,5) the second ring only two (1,4).
Markings:
B18E: 1-3
B18EP/FP, B20F: 1-4
B18FT: 1-3-5
B18FT mkII: 2-3
B20F mkII: 2-5
Markings:
B18E: 1-3
B18EP/FP, B20F: 1-4
B18FT: 1-3-5
B18FT mkII: 2-3
B20F mkII: 2-5
Rover Mini 1000, june 2009-
- eEm
Got a bit confused with the dots but you mean that 1 and 3 are opposite the 5 on the belt end. Like so-
I thought I had a mk2 B20F for a second
Oh ?=33mm's
So what do you make of that?
Oh ?=33mm's
- Ettore Bugatti
The lowest ring in the picture is the first ring and the holes are numbered from 1 till 5. The upper ring in the picture is the second ring and the two holes are numbered 1 and 4.
So if a B18E cam has the markings 1 and 3 then the 3 can be found in the first ring, but it is unclear where you can find nr 1. Is it on the first ring or on the second ring? My information isn't clear on that one.
So I suspect that this is a first B20F cam since I see a dot in the second hole on the second ring (the upper ring in the picture)aka 4 It also should have a dot in the first hole, but again my information is unclear in which ring...
About the question mark. If that's 33mm then the valve lift is 30,8-(33/2)=14,3mm and that is a bit too much for a B18E (book value is 10,49mm@0,5mm lift)
So the X should be according to you be 30,8+16,5=47,3mm?
- Ettore Bugatti
- Ettore Bugatti
hmm, that is a way I didn't think off.
I will scan tomorrow the piece from the manual.
In the mean time check this out : http://www.chevyhiperformance.com/techa ... index.html
So your cam is 240 degrees (2x120), not the book value of 260...
- Ettore Bugatti
- Ettore Bugatti
Et voila:
This is a very rough indication. It seems that the cam only is 240 degrees, but that could be wear.
So anyone please measure your cam so then we can compare
- Ettore Bugatti
My graph is with zero lift, but I know that Volvo used different lift values for the cam marking so perhaps you cannot compare the cams...
These values are in the 0,5 -0,7mm lift. So if the B18E would be 260 degrees @0,7mm (for example) then the cam timing would be longer at zero lift.
Also I wouldn't be suprised if the graph would 5 till 10 degrees unprecise.
