how much boost will the standard turbo take (comfortably),
running 7psi but want a little more power, it's got rich mod.
standard turbo boost ?
Hi clio 480 turbo,
I'm running 0.8 Bar on mine!
Without any problem..
But also need more,
BTW, this is my first post here and I need any body to tell me how can I got a rich mod since I'm too far away from Europe!
Thanx
But also need more,
Thanx
Proud to be the only Syrian guy over here!
[img]http://www.bassool.com/up/store/sign-volvo2.jpg[/img]
- martinholmesuk
Re: standard turbo boost ?
confused.clio 480 turbo wrote:how much boost will the standard turbo take (comfortably),
Your run more then 7psi with a rich mod. Anyways the more boost you run the more heat it produces so kinda pointless. You need a better turbo really.
Audi TT
Audi TT
- Jamo
Yes and no,martinholmesuk wrote:confused.clio 480 turbo wrote:how much boost will the standard turbo take (comfortably),
Thats what the intercooler to cool hot air charge, you run more boost the intercooler cools it down as long as it's big enough.
How much boost depends on the turbo compressor map.
The T2 turbo really above 14-15 psi is not producing anymore compressed air it just heats up the air that is already compressed as it's outside it's effeciency range.
