resistor and tuned computer (purple)
V480TI
Post by V480TI » Mon Jul 09, 2007 9:58 pm
just wondering, I opened a tuned ecu and found (when compared to standard one with same colour and number) in stead of one resistor 2 resistors.
What resistance will they have ?!?
It's (or they when tuned?!?!?) are located behind a black plastic box where that air hose is going in. To measure turbo pressure or so ?!?
Thanks and greetz
martinholmesuk
Post by martinholmesuk » Tue Jul 10, 2007 7:01 am
It's tuned ecu, take them off and find out. Course it's not the only thing that makes it a special ecu.
yknot
Post by yknot » Tue Jul 10, 2007 9:07 am
post a picture please :)
volvo 480turbo 1990 RICHMODED, adjustable FPR, SSQV BOV, free flow exhaust. - sold
1.6 16v Suzuki Samurai with many mods.
Nissan Note DCi
Ettore Bugatti
Post by Ettore Bugatti » Tue Jul 10, 2007 10:21 am
The output signal of the MAP sensor (voltage) is modified with these two resistors. If you can see the colour combination on the resistors then you know the resistance (Ohm). Or just put a potmeter in it. Then you can choose the boost cut between 0 and unlimited bar (or psi).
There's only one but. The MAP signal is also used for the igntion timing. Lowering the MAP voltage too much you dont get the retard orginal intended. On the other side I have never heard complaints about this on this forum.
I believe you can change 5 parameters in de ECU (EZK) by resistors. (Boost cut, ignition advance, knock sensor sensitivity and 2 other things)
Rover Mini 1000, june 2009-
Robou
Post by Robou » Tue Jul 10, 2007 8:36 pm
Time ago a scandinavian guy published (not on this forum) a trick to change maximum set boost by changing the value of one resistor and getting rid of another one, involved were #206 and #207. It was quite primitive, but well followed up. (maybe because of that)
If you see two resistors soldered in and if they are horsepacked, it could very well be that this the altered resistor and horsepacking has been done to get the right value.
Too old to bother
480 Turbo midst '91
V480TI
2 resistors
Post by V480TI » Wed Jul 11, 2007 9:47 am
indeed, 2 resistors soldered in in stead of one and they are packed.
they are located r207.
greetz
R5_B18FT
Post by R5_B18FT » Wed Jul 11, 2007 1:48 pm
pics and values please !!!!
thanks :D
Robou
Post by Robou » Thu Jul 12, 2007 11:57 pm
Maybe you want to start from scratch and undo the "tuning" ? In that case it may help to know that R206, which probably has been removed, originally has the value of 10 KOhms and R207 was originally 4.7 KOhms.
Metaloxide resistors were used for stability in time, accuracy 1%.
Too old to bother
480 Turbo midst '91
Post by pol » Fri Jul 13, 2007 7:17 am
This does sound familiar actually. I remember reading this too. I'm sure there was instructions on the FAQ... I'll have a look.
Post by pol » Fri Jul 13, 2007 7:21 am
http://www.volvo-480-europe.org/clubdat ... h/0412.php
I have read it on an external site somewhere a while ago also....
bbf
Post by bbf » Fri Jul 13, 2007 1:03 pm
i have done this conversion, it lasted for about 100km, than back to standard - as the ECU finds out, it was twicked and sees it as an error and compensates it. but was fun when it worked!
'86 480 ES, RIP :(
'91 480 Turbo, RIP :(
'93 480 2.0, RIP :(
Ettore Bugatti
Post by Ettore Bugatti » Fri Jul 13, 2007 5:04 pm
Maybe this will fit:
http://www.jdsporsche.com/sharktuner.html
The JDSPorsche LH2.3 SharkTuner for the Porsche 928 (MY 1987 onwards) allows the optimisation of the fuel and ignition maps to ensure optimum performance from the engine. This is particularly important if the engine has been modified in any way e.g. change of exhaust system, supercharger.
The SharkTuner is a hardware interface between the LH ECU (fuel injection computer) or the EZK ECU (igntion computer) and a laptop computer. A custom Windows interface program runs on the laptop, and a slave microcontroller in the SharkTuner acts as the interface between the laptop and the LH ECU.
The SharkTuner allows the operator to make changes in real time to the software of the LH ECU by modifying a special EPROM binary files provided with the SharkTuner. The standard EPROM is unplugged from the LH ECU, and the SharkTuner data lead plugged into the EPROM socket.
The SharkTuner is powered by the diagnostic connector fitted to all 928s. When any changes to the EPROM data have been finalised, these changes are saved, and this new data file is programmed into a new EPROM, using a low cost EPROM programmer. This modified EPROM is then fitted to the remapped ECU, which then can be refitted to the car.
The SharkTuner is now also available with a LH2.2 update option which allows full fuel remapping for the 85/86 LH2.2 equipped early US/Euro 32v (engine types M28/43 & 44 and M28/45 & 46), and also the Euro 16v LH2.2 MY85-86 (engine type M28/21 & 22). Please note that the early MY 84 Euro 16v is not supported at present. Some features available with the LH2.2 SharkTuner are not available with the LH2.2 version, as indicated below. This update also adds a set of auxillary inputs which can be used for real time monitoring and datalogging of external sensor inputs e.g boost sensors. The WBO2 input law can also be editted for use with more variants of WBO2 systems. Please refer to the LH2.2 User Manual, available from the link on the left of this screen.
Looks very promising. Although the price is a bit steep.
R5_B18FT
Post by R5_B18FT » Sun Jul 22, 2007 10:32 am
i cant imagine them still wanting 1250 dollars for it.....i emailed the chap, we'll see.....
rpruen
Post by rpruen » Mon Aug 13, 2007 7:52 pm
Ettore Bugatti wrote:Maybe this will fit:
It would fit the ECU ok, but unfortunatly the map locations are not going to be the same.
I would think the maker could adjust it to fit the 480 if they wanted to.
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
