external oil cooler
external oil cooler
Whitch one can be addapted ? Anyone else used an external oil cooler ? I tried tu use de renault 5 turbo and de opel vectra ce20let but the sandwich plate adapter at the oil filter was a bit larger. Any ideas ?
[img]http://forum.4tuning.ro/imagehosting/87447bb339649274.png[/img]
- JohnTurbo
I would have thought so!!
If you don't know, my advice would be to monitor oil temperatures via the infocentre and add an oil cooler only if required.
Bear in mind the turbocharger isn't relying on the oil for cooling on the 480.
Theres a nice alloy radiator type oil cooler found on some turbo diesels. I have one kicking around off a rover 418SD for instance.
I don't recal anybody ever adding an additional oil cooler to a 480, but i could easily be wrong. Theres been plenty of hot setups power wise too.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
5 gt turbo will work , just get rid of the original system , use an pair of pliers to unscrew the orginal socket . next step fit the original stuuf from the 5 gt turbo , i will post some pictures tomorrow
Renault 5 GTT *volvo 480 turbo power*
161 BHP & 230 Nm @ 10 Psi -->Now running on 18 Psi :P
soon --> new engine in with 315cc injectors t25/28 turbo an BIGMOD :)
cooling the oil doesn't just aid cooling, it helps the oil maintain its visocity, therefore the oil pump doesnt have to work so hard to keep pressure up and force oil into tight spaces. or so i read.
steve
steve
Renault 5, 1.7 volvo turbo engine, turbo technics turbo, lowered on koni, scorpion stainless exhaust, samco and stainless pipework, front mount intercooler, about 170 bhp.....more to come!
- vins480t
- Location: Nw & St. Jland. . . Drives: a 960 . . . . On my mind: Baby in the car!
viscosity has to do with the oil itself and the temp
i run 0W40 castrol full synthetic and i dont want my oil under 95 and above 115 deg celsius
before the extra cooler was installed it went up to 125 deg.
the oil can take it but it gets to thin so it wont grease enough is my thought about this.
- crispy-d
Vins480t - do you have an air duct or something feeding air to your cooler there, as it's right above the turbo! Thought that's the hottest part of the engine bay, and is usually glowing red hot under my bonnet!
If there is an air vent or something similar, does it matter if rain gets in and falls on the piping hot manifold? Very interesting, I didn't realise people were putting oil coolers on their cars as I thought these engines already had them, not that I've managed to find it!
The 5-30 Shell Helix FS stuff I use is pretty good. We did viscosity and some other simple tests on it (including some other standard oils) up to pretty high temperatures. Can't remember how high we went though, so if it was less than 125C then maybe I need an oil cooler?! lol I don't have an IC so have no idea what my temperatures are, but I do the 230mile motorway thrash from Bristol to Ipswich quite often, and I've never had a problem with the engine itself. (Apart from cambelt - but that was cos the stupid mechanic forgot to renew the blasted pulleys).
I take it the cooler just plugs straight into the oil circuit? Sounds easily done - would positioning it at the front of the engine bay be no good?
BMW E39 M5
Land Rover 110 V8
BMW E39 M5
Land Rover 110 V8
- VanDerGraaf
- vins480t
I cut in a complete new hole in the bonnet, same size as the excisting hole.
took an old bonnet and cut out the intake of that and poly-ed in that in the new hole.
so i got 4 ribs extra.
my scoop is 5 inch longer than the original.
So no water can go on the turbo directly. but when driving of course there will go water in there.
The reason I wanted a cooler oil wasn't because the oil looses his properties. The pistons are cooled whith oil . The combustion camber is in the piston. So ... if i give more boost , more power results higher temperature. If I don want my pistons to melt i need to cool them . So ... if the oil is cooler my pistons will be cooler . This is why I wanted to "extra" cool the oil. My specs are T25/T28 hybrid turbo , 350 cc fuel injectors and a nitrous kit. I intend to use Daftek Unichip for my electronics with a suplimentar map sensor (3 bar) . I am thinking that if I run , let's say , 1.3 bar of boost + 50 hp nitro setup if I don't extra cool the oil it will be "bye bye pistons , engine , and so ... " .
