That's what I call a special 480 engine
Richards engine really is a super mod! Done with help from Chris1roll and MrEd somewhere in Somerset.
- guitarcarfanatic
Is it back out again?!
Previously...
1989 Black ES - Great runner
Previously...
- guitarcarfanatic
Yeh I know. Seen it in various stages of build it's just I was up a couple weeks ago and it was back in the car! Apparently it's been in and out quite a bit though!
Previously...
Previously...
- tobi480turbo
Hi,
Yes that´s how an engine has to look like
everything nicely done and reworked and not to forget the supercharger and the very laaaarge turbo
- hjkort
My GOD!
What kind of boost does he want?
Looks like he's going to need 2 injectors per cilinder
Forged rods?
Forged pistons?
Forged crank?
Or are you trying to see how far and how fast this engine can spit out the pistons?
Hope all is going to work though... LOL
Forged rods?
Forged pistons?
Forged crank?
- tobi480turbo
Hi,
as far as I know does he want to run the engine with 2.5 to 3 bar of boost pressure, the pistons are ceramic coated to withstand the thermal exposure, in fact of the rods and the crank I don´t know exactly if they´re forged but the rods are balanced and new bearings are fitted.
Tobi
Tobi
if the engine is black ... how do you know if you get an oil leak?
only kiddin'!!
only kiddin'!!
Honda Civic ES I-VTEC
previous:
BMW E46 330i SE Touring
VW Mk4 Golf V6 4Motion
previous:
- tobi480turbo
Yes for sure this is a proper done job ... and also seems like very time consuminghjkort wrote:Seems a proper job then...
- VanDerGraaf
Yeah, I second that- although frightening is another word that comes to mind!
380bhp- that's the most pessimistic estimate!!!
Oh, and thanks for your help Richard on my questions today.
Previously:
'97 Saab 9000 Aero gone
Grey '88 ES dead
Previously:
Grey '88 ES dead
- rpruen
Well the huge underbonnet fire should be a dead giveaway.piper1st wrote:if the engine is black ... how do you know if you get an oil leak?
only kiddin'!!
It won't leak for a while, all the seals are new, everything refurbished, and with a much bigger crankcase breather system.
Being truthfull anything that is going to go wrong is going to be explosive, and easily detected.
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
- rpruen
Only about 2.5 to 3 bar.hjkort wrote:My GOD!
No I have some deforming disc type injectors, rated at 760cc/min at 3 bar. They open and close about three times the speed of the standard injectors, so it shouldn't be a problem.hjkort wrote: Looks like he's going to need 2 injectors per cilinder
Pistons are forged as std, and reworked to lower the compression. They are then ceramic coated to increase the sterength, and also provide a heat barrier.hjkort wrote: Forged rods?
Forged pistons?
Forged crank?
The crank and rods where tested by a mech eng firm, and are strong enough, as long as there isn't repeated heavy detonation (would bugger the rest of the engine as well). The head is also ceramic coated, so as to reduce the heat load on the cooling system, as well as resist high temperatures / moderate detonation.
That is always a possibility, I hope it works too. If not then I may as well have poured massive ammounts of money into a hole, and set it on fire.hjkort wrote: Or are you trying to see how far and how fast this engine can spit out the pistons?
And yes before anyone says, I know it could all go horribly wrong. I'm ready for that to happen, though I may not be happy about it if it does. I'm not silly enough to ignore the possibility.
Richard
- rpruen
It's going to take a while to get that power, the ECU needs to be re-mapped, and that's going to be done slowly, and with care. I have the basics for up to 2 bar ish. From there it's going to take plenty of time, so that I don't damage the engine.VanDerGraaf wrote:Yeah, I second that- although frightening is another word that comes to mind!
No problem with the questions. Glad to help out
Richard
- Murf
But if you dont try, you'll never know what could have been!!And yes before anyone says, I know it could all go horribly wrong. I'm ready for that to happen, though I may not be happy about it if it does. I'm not silly enough to ignore the possibility.
I know where your at, ive spent circa £4.5k on a 20 year old toyota ive never even driven! Pick it up tomorrow so i guess i'll find out then!!
Good luck
Kia Pro'ceed GT 1.6 Turbo
1992 480 Turbo
2007 Focus ST
1992 480 Turbo
2007 Focus ST
- rpruen
I'm not saying how much, but the pipework to connect the turbo and all the other bits together is over 1k.Murf wrote: But if you dont try, you'll never know what could have been!!
Good luck
Some over engeneering has also gone into the project, but that should act as insurance for minor mishaps. The thing is to not get too adicted to turning the boost up and blow the whole thing to bits. It needs to be done slowly in managable steps. That may be something I need to watch out for
I'll hapily share the details with anyone who wants to duplicate the project, but my initial advise would be don't.
Richard
- tobi480turbo
Hi,
nice to see you back again here
hope everything is about to work out fine with this "insane" engine
Tobi
Tobi
