480 with sliding vinyl sunroof in Haarlem, Netherlands
When you spot a 480 and wonder if it's someone from the forum: ask it here! One rule: do NOT post registration plates.
Van
Post by Van » Sun Apr 21, 2019 6:49 pm
For about two weeks I spotted a black 480 with a sliding vinyl sunroof in Haarlem, Netherlands. I've never seen a 480 with an opening vinyl roof before.
Re: 480 with sliding vinyl sunroof in Haarlem, Netherlands
Post by jifflemon » Sun Apr 21, 2019 7:01 pm
Please say you’ve grabbed a pic?
480 Expert
Post by brinkie » Sun Apr 21, 2019 7:05 pm
I know whose car that is. Don't have a pic right here, but the roof is from a Renault Twingo.
AleksanderHugo
Post by AleksanderHugo » Mon Apr 22, 2019 7:30 am
I think that some company (Westfalia perhaps) used to make these aftermarket roofs.
Once I came across a photo of a 480 with such a roof:
Post by dragonflyjewels » Mon Apr 22, 2019 8:52 pm
One of our French 480 club friends has fitted a Twingo sunroof as well, made a cracking good job of it
Interestingly, the French cars don't have a high level brake light, so I took a rear hatch over for him.
Sven - 1994 Dark Green GT
100
Post by 100 » Tue Apr 23, 2019 9:06 am
There is a high level brake light?
2005 Renault Clio V6 255
1962 Land Rover Series II
Post by jifflemon » Tue Apr 23, 2019 10:08 am
Above the wiper - Perhaps more a "mid level brake light"
Van
Post by Van » Wed Apr 24, 2019 6:59 am
It was driving and there was no time to take a picture, I spotted the 480, and only then the roof. It was the first 480 I'd seen in a couple of years actually.
arthuy
Post by arthuy » Wed Apr 24, 2019 9:31 am
Smart looking addition and solution to leaky sunroofs.
Van
Post by Van » Tue Apr 30, 2019 9:46 pm
Often it is referred to as the third, or center brake light.
480 Expert
Post by brinkie » Thu May 02, 2019 10:33 am
Just a thought. The roof is part of the car's structure and an additional crossmember gives extra torsional rigidity. This is why the roof of a car with moonroof is different, the crossmember is located further aback.
If you take out both the metal roof and the crossmember connecting both B-pillars, will there be enough structural integrity left? Won't the body start suffering from twisting and subsequently negatively impact roadholding, like most convertibles do?
Post by Alan 480 » Thu May 02, 2019 11:20 am
not sure, on the Reliant Scimitar SE5a the full length sun roof was fitted by chopping the roof out and the roll over bars in roof were cut off and simply bolted to the wooden frame!!!
I fitted a full length opening GRP roof (used a roof from a scrap car in two removable sections) and refitted the two tubes, although they were a 'loose fit' in a mount at bottom of door !!
Post by jamescarruthers » Thu May 02, 2019 11:42 am
Having crashed and rolled a 480 quite spectacularly and crediting it with saving my life, I would be very reluctant to remove the roof bar. I imagine the sides will fold over should the car end up on its side.
Don't get me wrong the roof looks great, but it isn't sensible when you think about it from a structural point of view. The roof bar isn't just for show, it will have a designed and calculated purpose!‎
