Seatbelt arm replacement - how to (with pics)
piper1st
Post by piper1st » Mon Apr 10, 2006 11:54 am
It's not often I get to provide info to people on the forum ... and I know this one is VERY easy, but since members are asking and I just replaced both arms on my GT at the weekend, here is a 'How To'. ;)
Items Required:
8mm Allen Key
Phillips screw driver
Replacement seatbelt arms (see below)
Mallet (maybe)
Description ----- Part Number ----- Unit Price ex VAT
ARM L.H. ........... 3450814 ................ £5.50
ARM R.H. ........... 3450816 ............... £5.50
Step 1:
Remove rubber surround on the coat hook to reveal the Phillips screw as detailed in the pic below.
Step 2:
Remove the screw from inside the coat hook and remove the plastic panel to reveal the seatbelt mechanism. (As show in the picture below).
Step 3:
Keeping the arm raise (as in the pic above) to reduce the amount of tension from the spring. Use an 8mm Allen key to loosen the bolt (sorry, the pic below is the passenger side). You may need to use a mallet or something to get it started.
Take care when loosening the bolt as you will be aware the spring is attached to the seatbelt arm so it is important to keep the bolt straight to provent ruining the thread on the bolt or the car.
Step 4:
Once the bolt is completely out, remove the spring by twisting the arm ... then remove the broken seatbelt arm and replace it with the new one.
Reassemble
To put back together again, do the reverse of the above steps.
I hope this is of use and if there is anything I?ve missed, let me know and I?ll edit it in!
Ross
**** EDIT ****
Clubman Dan's tip:
the only thing i would add is that if you lift the spring up you can unhook it from the top where it mounts on to the car, then you have no tension on the bolt. i am guessing it would be easy to cross thread, especially when putting the bolt back in.
once the bolts in you can lift the spring back in to the bodywork.
Honda Civic ES I-VTEC
previous:
BMW E46 330i SE Touring
VW Mk4 Golf V6 4Motion
robin_xr4i
Post by robin_xr4i » Mon Apr 10, 2006 12:42 pm
Well done that man, top step by step! :D
LANTIN
Post by LANTIN » Mon Apr 10, 2006 12:50 pm
:cheers:
Brilliant ! I just needed that.
Mitch
Post by Mitch » Mon Apr 10, 2006 5:09 pm
Thanks Ross. This is just the sort of help some of us need. We are not all mechanically or technically minded, but I for one am happy to tackle simple repair jobs like this. I don't know about the rest of the girls on here, but step by step instructions like yours are brillliant. I literally didn't know where to start with this job, but now I feel quite confident to do it myself. Congratulations. Perehaps this could be the start of more "How To" items. There are enough experts on here :wink:
Thanks again.
Mitch
1995 480 Celebration (#467/480) Flame Red
1991 480ES Black metallic (deceased)
stu chacks
Post by stu chacks » Mon Apr 10, 2006 5:33 pm
Nice1 Ross, if only it would put the spring back into the seatbelt retraction at the same time huh? You just never know what's hiding behind them there panels.
Just need someone to do a guide on replacing the bulb in the ignition illumination next - looks like the steering wheel has to come off when I had a butchers the weekend as 2 screws just sitting behing the wheel on the lower casing. Grrrrr.
Stu.
piper1st
Post by piper1st » Mon Apr 10, 2006 8:51 pm
thanks for all the positive response to my 'How To'.
Mitch wrote:I literally didn't know where to start with this job, but now I feel quite confident to do it myself.
HAPPY DAYS!! good luck!!
stu chacks wrote:You just never know what's hiding behind them there panels.
stu ... thats just it! its always better if you know what to expect!
stu chacks wrote:Just need someone to do a guide on replacing the bulb in the ignition illumination next.
Sound like a dare to me ... ;)
previous:
Joolz
Post by Joolz » Mon Apr 10, 2006 9:57 pm
Excellent........10/10
cant wait for mine to break now!!!!! and we all know one will one day ;)
Volvo 480 Celebration 466 Dark Grey Metallic (PUS)
previously
Volvo 480 2 ltr Paris Blue
Volvo 480 2 ltr Peacock Green
Volvo 480 1.7 White
Volvo 760 GLE Saloon 2.8 V6 Blue
guitarcarfanatic
Post by guitarcarfanatic » Tue Apr 11, 2006 12:34 am
Stu.
I'm guessing you have a airbag? On the non airbag cars you just turn the wheel until you can undo the screw and then do the same on the other side. I imagine with an airbag you would have to take teh wheel off!
Previously...
1989 Black ES - Great runner
Mitch
Post by Mitch » Thu Apr 13, 2006 3:23 pm
Job successfully completed and only two broken nails :D
Many thanks to Ross
Mitch
chigo
Post by chigo » Thu Apr 13, 2006 6:04 pm
excellent work ! this weekend i'm busy now :D
Thank you !
Red 1990 Volvo 480ES
[img]http://www.geocities.com/dtabo75/avatars/go480_ani.gif[/img]
piper1st
Post by piper1st » Fri Apr 14, 2006 2:36 am
Mitch wrote:Job successfully completed and only two broken nails :D
Many thanks to Ross
Your very welcome ... and well done yourself!
previous:
Moongoose
Post by Moongoose » Sun Jul 23, 2006 6:41 pm
Thanks Man!
Someone obroke mine today and I was looking for something like this.
Hi from Spain!
piper1st
Post by piper1st » Mon Jul 24, 2006 9:04 am
Moongoose wrote:Someone broke mine today and I was looking for something like this.
I'd be looking for a window to chuck them out!! hehe!! :lol:
Hope it all goes well!
Hi from Scotland!
previous:
wreeve
Post by wreeve » Mon Jul 24, 2006 9:41 am
Thank you. I am more impressed by the price! I managed to snap mine the second time I got out of the car and though Volvo would want an arm and a leg for the replacment!
480 Celebration number 133
Too many 6 cylinder Vauxhalls
TR7 V8
ozturbo
Post by ozturbo » Tue Jul 25, 2006 10:21 am
The ignition switch light is easy - just two screws to undo and remove the cover under the steering wheel. The light is a common garden variety bulb with the flat base. Took no time at all to do mine the other day. Some idiot cracked the cover on mine at some stage though. Why do people always over tighten screws on plastic bits? I've seen it a million times over the years.
1990 Volvo 480 Turbo white
1988 Alfa 75 3 litre V6 red
1990 Alfa 75 Potenziata 3 litre V6 black
1992 Alfa 164 3 litre V6 red
1981 Alfa GTV 2 litre red
clubman_dan
Post by clubman_dan » Fri May 25, 2007 11:46 am
good guide there, i just did my passenger side one today, very easy!
cheers
Dan :)
'95 2.0 es SOLD!
'86 mini 1380 rather fast!!
muddyfox470
Post by muddyfox470 » Wed Jun 13, 2007 1:44 pm
Cheers for this it was invaluable. however the bolt was so hard to get off, had to use the force of a mallet to start it off :)
Also I just bought a pair of seatbelt arms, and they are currently £5.50 exc VAT each in case you wanted to update your post.
Again cheers :)
Ian
(Click for pictures :D )
paulsgarden
Post by paulsgarden » Fri Jul 06, 2007 6:55 pm
great how to but you forgot one thing .
those blody springs bit. ;)
piper1st
Post by piper1st » Sat Jul 07, 2007 2:13 am
No worries Ian, thanks for your kind words!
muddyfox470 wrote: Also I just bought a pair of seatbelt arms, and they are currently £5.50 exc VAT each in case you wanted to update your post.
Cheers and duly up-dated! :D
paulsgarden wrote:great how to but you forgot one thing.
Cool ... i can't quite remember exactly how i did it now, so i'll copy in Dan the Clubman's comments. :D
previous:
Dutchman_in_uk
Post by Dutchman_in_uk » Fri Sep 14, 2007 9:57 am
Absolutely brilliant walkthrough, piper!
I do have to throw in a total newbie question though...
Are those arms ordered through your local Volvo dealer or is there a place online that I haven't found yet? Ebay charges 15 quid!
