Broken seat-belt arms
Post by dcwalker » Tue Sep 14, 2021 8:49 am
Most of us have been there - the impatient mother-in-law/clumsy friend (here insert an appropriate person) insists they can get into the back without moving the seat-belt arm (here insert any other appropriate scenario) and there is the snapping sound of another piece of unobtanium biting the dust :( :cry:
Although not the only point they can break, the usual problem is that the small prong that holds the roller fitment snaps off:
Having seen mention of repairing these in a number of places, and given that these arms are simply a convenience and not an integral part of the seatbelt (which in my view should never be repaired) I thought I'd give it a go and do a "How To" at the same time.
Usually when these prongs snap off it isn't a clean break, meaning you can easily see exactly what angle they need to go back on.
Take a blunt ended (ie not self-tapping screw) and cut it to about 1 cm length - I used a screw designed for fixing a household socket to its back-box, because it is a good width and has a fine thread, meaning it should get a good grip. You can see it on the bench in the above photo - discard the part with the head on it.
Then carefully put a blob of paint in the centre of the broken end of the prong and gently press it into position against the rest of the arm - that will give you a location mark for drilling:
I used some red acrylic modelling paint but anything that isn't instantly dry would do...
Current: 1994 480 GT, 1995 Celebration 331 (plus 2013 V60 D5 SE Lux Nav & 1995 440 ES)
Re: Broken seat-belt arms
Post by dcwalker » Tue Sep 14, 2021 8:54 am
Next comes the drilling. Be gentle and start small, working up to the size you need (which in the case of the electrical screw I used was 3.2mm).
The drill in the photo for my starting hole is 1.5mm:
I then worked up via 2mm, 3mm and finally 3.2mm. Obviously you need to drill both parts which is where the red dot comes into its own.
Then screw the threaded, headless shank that you prepared earlier into one of the parts to be joined. First time around I screwed it into the prong as per the photo, but second time I screwed it into the arm first - which seemed to be the easier way to to it, given you need to hold the threaded shank with pliers to turn it in, whereas it is then quite easy to screw the prong down onto the thread:
Apply a little super-glue into the holes and around the area to be joined - the breakage "scars" will show you where...
Post by dcwalker » Tue Sep 14, 2021 8:58 am
Then treat yourself to a well-earned cup of tea while the glue dries:
Et voila! They seem to be as robust as they ever were :D :
And before anybody asks, that pair is off to join the Rescue Group stocks to find their way onto the cars we have in progress ;)
Spainal
Post by Spainal » Wed Sep 15, 2021 3:43 am
Hey dcwalker!
Good information, but I don't have such, well, I would buy!
Do you know where you can buy these?
Volvo 480 Turbo!
I was born and live in Siberia! :hopping:
Post by Alan 480 » Wed Sep 15, 2021 11:33 am
I don't think that new are available, in any shape or size :(
another 'unobtanium' item....
3D printed parts might work?
malkontent
Post by malkontent » Wed Sep 15, 2021 4:54 pm
Hi
Have one used , complete , 3 parts / arm , tringle and rolle / , in very good condition , since there is no part number , do not konw which side it is .
Spainal
Post by Spainal » Thu Sep 16, 2021 10:16 am
Hi
Can you send me a photo by mail or watsap?
Volvo 480 Turbo!
malkontent
Post by malkontent » Thu Sep 16, 2021 10:50 am
Spainal
Post by Spainal » Fri Sep 17, 2021 4:32 am
How much will you pay? I need 2 pieces, left and right.
Volvo 480 Turbo!
malkontent
Post by malkontent » Fri Sep 17, 2021 7:14 am
Sorry only this one , 45 € + post charges .
Spainal
Post by Spainal » Fri Sep 17, 2021 7:43 am
Sorry, dear to me for such a thing!
Volvo 480 Turbo!
malkontent
Post by malkontent » Fri Sep 17, 2021 7:51 am
no problem , is waiting :D
