removing rear lock
Posted: Sat Jun 16, 2018 8:18 pm
by malkontent
Hi
Removed all electric connections , linkage , lock core / do not forget to insert key ! / and left only yellow metal casing ...and
could anyone help ?
regards
Re: removing rear lock
Posted: Mon Jun 25, 2018 5:35 am
by malkontent
Nobody ?
Posted: Mon Jun 25, 2018 7:59 am
by WRDendy
I'm afraid I don't know, but it
looks like arthuy does. Might be worth a PM?
Posted: Tue Jun 26, 2018 7:45 pm
by malkontent
Came to that place :
outside
and inside , what now ?
Posted: Wed Jun 27, 2018 12:12 pm
by AleksanderHugo
The next step is to remove the metal bracket that holds the microswitch. If I remember correctly then all elements detach.
Posted: Wed Jun 27, 2018 5:33 pm
by malkontent
It is not so easy
, send a PM to Arthuy , he did this . Look closer to my picture , I removed a small screw at the bottom , but can`t move a yellow casing aside , because of aluminum "pipe" which goes from inside to outside , at the end of that "pipe" is a rubber ring . So I think , the only way is to remove /but how ? / that pipe , outside !
Posted: Sat Jun 30, 2018 12:02 pm
by arthuy
I knew I should have took some more photos.
The yellow metal plate holds the alloy barrel in place. It is just a push fit, you need to lever it off, a long flat screw driver usually works.
Looks like you still have the switch fitted, pull that off too. The lock comes out from the outside.
If you are going to reuse the lock you need to save the little brass spring and ball bearing.
I will try and get some photos next time I am at the spares car.
Posted: Sat Jun 30, 2018 2:55 pm
by malkontent
Thank you very much
, now it is clear .
Posted: Sat Jun 30, 2018 6:05 pm
by arthuy
Let us know how you get on.
Posted: Tue Jul 03, 2018 7:57 pm
by malkontent
Posted: Sat Jul 07, 2018 2:56 pm
by arthuy
Do these help?
Remove the little screw and prise the retaining clip off.
Once this is off the lock will come out, might be stuck with age but will come out.
Posted: Mon Jul 09, 2018 8:21 pm
by malkontent
Hallelujah
Did it today , my mistake was , I tried to move yellow casing to the left / looking from inside the car / ,it must go to the right side ! Microswitch holds a alloy barrel , after removing it all is free and barrel goes outside .
