cannot believe how easy this is, ill up load pics asap
first remove plastic cover which has the red pin attached (all one piece)
secound undo sur-clip holding the back of the barrel in place
push the barrel out from the back through the front were you insert key
best to do with key in otherwise pins fly everywere
replace with new lock in opposite to instructions just given. easy!!
replacing the barrel lock (done drivers side)
- benwalllker
