Door Stay Repair
SteveR
Door Stay Repair
Post by SteveR » Tue May 12, 2009 1:25 pm
The following is buried away in a threads so it may be better here.
Because the 480 door is heavy, and heavier when car is on a slope or with e=wind behind, the door stay support area cracks and gives a tell tale cracking noise when opening the door - something to listen for when buying a 480.
Repair is relatively straightforward as shown in these links:
the first link is to remove the door card
http://www.smr46.co.uk/volvo/Door.pdf
and the second is to do the repair.
http://www.smr46.co.uk/volvo/DoorRepair.doc or
http://www.smr46.co.uk/volvo/StayRepr.pdf
I've found the thread now:
http://volvo480.dragons.org.uk/forum/po ... e&p=114018
Steve Robson
At Nurburgring (pic Suddy)
No longer a 480 owner :-(
