Door pods
Door pods
When I first had my 480 I decided to uprate the sound system by changing the speakers and adding amplification.
I did this and was happy with the result but I decided it was time for a change.
I saw a "how to" from Red and was inspired to take action.
I needed door pods to house some Boston pro 6" and 4" speakers.
The first thing I did was to make a template from card then transfer it
to 12mm MDF .
Then I cut two rings using a jig saw.A router would be better but if you
take your time its OK.
As you can see I have removed material to help set the anlgles and used
blocks to set the height.I used a hot glue gun here.
Both pods were at this stage so now the fun part.Using an old T shirt I
carefully streched over the form and stapled into position.
Having done this I coated the material with resin and left to harden.
Now comes the messy part. I covered using two layers of fibre glass
matting .This is to say the least a right carry on!
As you can see I then covered in filler .I also set into position on a bed
of filler after masking the doorcards.This process takes time and after
much sanding ,filling etc its ready for covering.
Fixing I made some iron brackets and welded studs .Photos to come
Hope you like
to 12mm MDF .
Hope you like
- benwalllker
- cliffeydawlish
lol
uve tried 3 times to make these door pods twice i endid up in hospital but ijust dont have the skills required will you please make me up a set for a pair of vibe components i will pay you and love you forever
- cliffeydawlish
lol
i honsetly just carnt grasp wood i draw a straight line it comes out zig zagged i try gluing the small bit off wood in to get the angle they dont stick but my fingures do
thanks anyway but ill call it quits i think me n wood just dont go
ps this is my second 480 im doing prettyt well id say
Re: lol
So you already sent one to heaven?cliffeydawlish wrote:i honsetly just carnt grasp wood i draw a straight line it comes out zig zagged i try gluing the small bit off wood in to get the angle they dont stick but my fingures do
- cliffeydawlish
nope
still have both of them
Re: Door pods
Hi Kev, can I ask you a newbie question about the wiring for your project? I think there is a little tweeter in the door by the handle, do you need to branch of from your speakers to wire this in? Or does it only make a sound when I'm indicating? Thanks again!
Re: Door pods
the indicator buzzer is in the cem. the tweeters branch of from the speakers but you will need a high pass crossover in the line to prevent the lower freguencies from getting there.
you can buy them or make one
http://www.circuitstoday.com/tweeter-crossover-circuit
the variable resistor is there to adjust the tweeter volume, its the series wired capacitors that stop the low notes from getting through.
Re: Door pods
Thanks Ted! Much appreciated.
