Idle Control Valve
Idle Control Valve
Idle Control Valve (ICV)
I know this is a very basic job, but quite often ruling out the basics is the best way to fault find and hopefully this “how-toâ€
Honda Civic ES I-VTEC
previous:
BMW E46 330i SE Touring
VW Mk4 Golf V6 4Motion
previous:
Cheers Kev, I like to try ... hopefully everything is right!kev wrote:Fantastic job matey. You have a talent there.
Good Luck!kev wrote: I think I will give it a go !
previous:
previous:
- Dan the 480 Man
Done this two weeks ago because my car had lumpy idle issues and usually at the second lump it would turn off. Now it doesn´t turn off, but the idle is still a bit lumpy between 800 -1200 rpm, but i'm hoping it is the lambda sensor.
One major difference i noticed was that the car is smoother to drive, when changing gears. Before doing this to the ICV, revs would fall very fast, now when changing gears revs drop right where they should for the next gear. Great DIY.
Regards
Regards
- esta
Watch out Haynes! Very good info, think this is something i am going to have to do, and this is very easy to follow! Well done
HAVE: Jaguar XJ40 4l Sov
www.projectjaguar.co.uk
Cheers. Everyone helped me with the big jobs, so it's good to give back what i can!
Seatbelt arm's next?
previous:
previous:
- esta
I did this job Sunday afternoon, and it less thank half an hour, even including trying to find the carb cleaner
Worked a treat too!!
- Big Brother
- Moderator
- Paul240480
Fab guide. I'm going to use it cos my idle is as lumpy as a lumpy thing
Paul240480
www.gitessouthbrittany.com
[img]http://i280.photobucket.com/albums/kk165/Paul480/EarlyEveningMidOct-LaBelleVilaine.jpg[/img][img]http://i280.photobucket.com/albums/kk165/Paul480/RocketPhotos009-1.jpg[/img]
www.gitessouthbrittanytouring.blogspot.com
Cheers and good luck! I hope it helps.Paul Clark wrote:Fab guide. I'm going to use it cos my idle is as lumpy as a lumpy thing
previous:
previous:
- Paul240480
Okay, I followed this how to & got loads of muck out of my ICV. Obviously needed doing. Thanks again for the guide.
Unfortunately, in may case it did not solve my lumpy idle completely.
So having searched around I found another thing to check that I thought may be of use & worthy of a mench'
Check this thread - & my findings.
http://volvo480.dragons.org.uk/forum/vi ... hp?t=16344
Cheers, hope it's of use.
Paul240480
madmax2471
Re: Idle Control Valve
Hi, wheres the "how to" to clean the idle control alve?
Maybe its just me but I cant find it lol
any help would be appreciated
I've no idea where the "how to" is gone. I certainly did not delete it, must of got lost coming over from the old server?!
previous:
previous:
- Zoist
Is there any change to get the "how to do" back again?
It would be a great help
I still had the pictures on my photobucket account ... dunno if they are any help without the description tho!
previous:
previous:
zapcity
Don't suppose anyone can add the text to the pictures.
Is it just a case of removing the ICV, spraying carb cleaner into the ICV via the two pipe connections, and cleaning out the residue with the kitchen roll/cotton buds?
Thanks for any pointers.
1994 480GT
XC60 T8 (wife's rocketship shopping trolley) and XC70 D5 hack
C70 Coupé Convertible for the sunny days. Still got it! Should sell it but can't!
eye of ra
Looking at the pictures I would say yes.
When I did mine I ended up taking it apart as just cleaning it as you discribe made no difference. However having taken it apart and from memory having all sorts of fun putting it back together it still made no difference as my idle fault ended up being elsewhere.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
zapcity
Thanks. Will take the simple route 1st and go for the basic clean!!
1994 480GT
