First of all what have I tried?
- Check All Earths are earthed
- Check all Earths are connected to the right places
- Check and Double Check the Fuses
- Hit The Dashboard
- Check grey ribbon
- Check Radio Connectors **
- Check Info Centre Wires **
- Check Info Centre Circuitry **
These are the most useful threads I have looked at:
Dead Info Centre
Info Centre Back Lighting, but with no information
480 infocentre display help
Have I missed anything out or what else can I try to find out whether my info centre is working? I haven't driven it at night so I cannot comment on the lights etc working/not working. I did, however, shine a torch at the display to see whether I could see any information, but I couldn't
I also need to check the bulbs and buy some replacements, so is there any chance that anyone could tell me all the bulbs I need for the dashboard/display?
I will also take out the panel again and recheck the wires and make sure they are all securely in the connector and then securely in the back of the panel. Is tehre anything else I can check with regards to the info centre? The previous owner said it used to come on and off, however for me I have not yet seen it come on at all
Sorry for all these threads but I thought I better amalgamate it all and make it easier for similar numpties like myself
Thanks in anticipation
Ian Ruscoe
EDIT: I forgot to say most of the other things on the same circuit are working, however the key hole light (for the ignition) has yet to come on/work...
